Thread: knee Airbag igniter fault - short to ground
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. knee Airbag igniter fault - short to ground
    Dec 2013
    East Sussex, UK
    Hoping for some assistance with regards to a fault that has started reporting on my Audi A6 3.0tdi.
    The fault is front passengers knee airbag igniter - short to ground.
    Tried resetting it with Vagcom but fault comes back immediately. Therefore I stripped out the passenger side glovebox to check the connectors. What I have found is that there is actually no knee airbag on this side of the car....there are also no connections present for a knee airbag on this side. The airbags in the upper dash are present and I removed and refitted the connections for these just to see if that would affect the fault.
    Advanced measuring values showed that there was a 'too high' value reporting on the drivers side knee airbag igniter so I wondered if this was causing the issue. Therefore I stripped out the drivers side lower dash....only to find that there is no knee airbag on this side either? Again there are no connectors present for airbags either.
    This has obviously left me a bit confused. I have owned the car for nearly a year now with no issues and the fault only started reporting last month for no apparent reason. The fact that there are no airbags fitted in these locations is what is confusing me?
    Any advice would be gratefully appreciated. I would post pics up but I am unable it seems to attach photos to the thread.
    Audi A6 Avant - 3.0 tdi Quattro - S-line Le Mans edition
  2. Re: knee Airbag igniter fault - short to ground
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Our seats started giving a too high error at some random time. It's quite common with various of the airbag layouts, due to resistance getting too high for some reason in the multiple controller to airbag connectors. As fitted there are two in our seat: one at base of door pillar, one under the seat. Cutting out the pillar one and crimping wires fixed it for me.
    Not having the bags makes it difficult to do this of course . What are the actual error codes?
    Can you see the resistance in the other circuits in VCDS? I was able to use a pencil lead and croc clips to figure out what resistance would keep the system happy, and popped resistors in from Maplin as a stop gap until I got the bit of loom that I needed.
  3. Re: knee Airbag igniter fault - short to ground
    Dec 2013
    East Sussex, UK
    Thanks for the reply.
    The fault code in Vagcom is 9440785
    Front passengers knee airbag igniter B100E 11 (137) - Short to ground
    I've just removed the entire centre console and disconnected and reconnected the airbag module in case that is the issue...no change to fault.
    I wonder if anyone has the wiring diagrams for the A6 C7 2012 3.0tdi S-line Quattro. Given that there are not actually any knee airbags in this vehicle I'm figuring that I could perhaps cut the wiring just after the plug assembly and the solder some resistors in line which would then clear the fault code.
    Really frustrating as there is no reason why it has come on....all I can surmise is that perhaps a wire has been chafing somewhere or been caught and has finally created this issue even though the actual airbags don't exist in this vehicle.
    No point taking it to Audi as they will just want to take my pants down to investigate a fault like this!
    I would post pictures up but there seems to be no way to do this via a mobile phone browser?
  4. Re: knee Airbag igniter fault - short to ground
    Dec 2013
    East Sussex, UK
    Well I've stripped out the centre console and the left hand side b pillar and left hand side lower trim so I can get to the plugs for the airbags on that side. Located plug 17p in that area and checked the wiring....none of it shows continuity to earth on either side of the plug.
    Then went to the airbag ecu plug. The wiring diagram I have shows pins 45 and 46 as being the pins to the passenger side knee airbag..... well I don't even have those pins present so now I'm questioning whether I even have the right wiring diagrams for the A6 even though it shows Audi A6 all over it.
    Frustrated as hell right now. The only pins that bell out to earth at 75 ohms are pins 51 and 76 which are both black and white stripes.....
    Wondering if the actual airbag control unit is faulty....given that the wiring does not bell out to earth which implies that there is no short to earth?
    Any advice appreciated....or even some wiring diagrams for the airbag circuits.....just in case mine are actually incorrect. My diagram shows that pins 45 and 46 on J234 go to the pass side knee airbag and that pins 43 and 44 go to the drivers side knee airbag....i don't have these items fitted and the pins aren't present in the main airbag control unit plug J234.
    Thanks in advance
  5. Re: knee Airbag igniter fault - short to ground
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    What airbag modules show in VCDS? Have the knee ones been coded in by mistake?
  6. Re: knee Airbag igniter fault - short to ground
    Dec 2013
    East Sussex, UK
    Just rebuilding the car so i can drive it at the moment. Will reconnect once I'm done and get some screenshots of the coding data for the airbag module.
    I've owned the car for 12 months now and the fault only arose a few months ago.....the module has not been coded or had the code changed in that time?
    I understand what you are saying....maybe if someone without knee airbags fitted could send me a shot of the long coding from their VCDS then I could perhaps try recoding my module? Or at least compare the coding.
    Contacted Audi for a price on a new airbag control unit.....£680 plus VAT !!
    The investigation continues....however I'm getting good at removing audi interior panels which will stand me in good stead when I install the reversing camera at a later date.
  7. Re: knee Airbag igniter fault - short to ground
    Dec 2013
    East Sussex, UK
    So I've refitted everything I removed....Needless to say the fault is still present. Given that the wiring for those components does not even exist in the plug or the car I can only surmise that the Airbag control unit may be faulty.
    I've checked the status of the components and knee airbags are not toggled in the control unit whereas the other airbags etc....show as 'activated
    Therefore I've ordered a 2nd hand airbag control unit to slave in and see whether that changes or clears the fault....ive also taken a note of the long coding in case I need to recode the module that arrives.
  8. Re: knee Airbag igniter fault - short to ground
    Dec 2013
    East Sussex, UK
    So I've received a replacement airbag module from Lithuania.....same part number etc....
    Have swapped it in but now have come up against the 'component protection ' issue.
    Cleared all faults on replacement airbag module with Vagcom....but unable to clear the component protection fault.....which keeps the airbag light on.
    Long coding can also not be altered using Vagcom....but this may be due to the component protection issue.
    There are lots of threads on ODIS etc.....being used to remove component protection in conjunction with VAS 5054A Interface....however I can't see how you can actually do this unless you have a license and access to the online server to enable you to remove componet protection.
    Does anyone know of any independents in East Sussex that offer this service....or am I going to have to go into a main Audi dealer?
    Has anyone successfully removed component protection using ODIS software and the VAS5054A interface purchased off one of the many sellers online?
  9. Re: knee Airbag igniter fault - short to ground
    Oct 2021
    Finland
    Did you find a solution?
  10. Re: knee Airbag igniter fault - short to ground
    Dec 2013
    East Sussex, UK
    Yes and no.....when the car was in my garage and fixing the coolant leak in the centre of the engine for approximately a week I found that the fault cleared ok using VCDS and didn't come back for a few months. It has since come back again and won't clear using VCDS
    As I said in the thread the wiring is not present.....there is no knee airbag as it is not specified on this particular model. My thinking is that the problem is moisture related and that this is creating an issue which is causing this reporting fault.
    I'm going to get to the bottom of it at some point. Need to address the issue with the front passenger door where you sometimes get water ingress during heavy rain that has been mentioned in the forum previously so perhaps that will have an effect. Electrical faults of this nature are always difficult to diagnose unfortunately 😕
  1. Question Airbag short to ground
    By Martynas26 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2015, 05:47 PM
  2. Airbag Igniter Fault
    By Boy in forum VCDS - Help Requests
    Last Post: 14-05-2014, 11:32 PM
  3. Please Help 00588 - Airbag Igniter; Driver Side (n95) fault
    By Cylon2007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2013, 07:33 PM
  4. Please Help Airbag Igniter Fault
    By Boy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2012, 06:48 PM
  5. Please Help Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    By Michael Blythe in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-01-2012, 05:29 PM
