Thread: replacement key Fob
Results 1 to 10 of 10
  1. replacement key Fob
    Dec 2018
    cardiff
    Hi ive had some issues with the Fob not working on my B7 S4, ive tried numerous link/sync methods but to not avail
    it just doesn't want to re-connect
    ive asked, but not sure if its just a transponder/chip issues as the car starts and runs off the key with no issues?
    if the transponder chip was duff then surely the car would not start?
    there seems to be nothing wrong/broke on the circuit board on inspection,
    so i think the only option is to get a new Fob or possibly just replace the transponder chip?
    obviously im looking on saving money so cant afford an OE Fob or dealer re-programmeing, so need some help with this
    most of the US guys have used the Ebay copy replacements and had no issues anyone on here done the same
    if so a link on what to actually get would be ideal, or possibly replace the transponder chip first?
    id be very greatfull for any advise as its getting to me having to use the key to open then car
  2. Re: replacement key Fob
    Mar 2019
    Canada
    Do you mean the keyless entry buttons don't work? That's a separate issue from the transponder chip in the key. I tested with my B7 when getting a remote starter installed. Removed the transponder chip from the key and tried starting the car-it cranks and starts but then immediately shuts off.
    I think there may be a problem with your keyless entry module in the car or the board in your fob. I have one spare key that starts the car with no issues (so the transponder chip is fine) but the keyless buttons won't connect no matter what I do. So I just keep it as a backup spare key.
    So I'd start with a new key
    I hope this helps
    Sent from my ONEPLUS A5000 using Tapatalk
  3. Re: replacement key Fob
    Mar 2019
    Canada
    To add to this, you could look up a local key cutter that programs keys. They'll cut and program the key with your car onsite. Then you can confirm before leaving that the keyless works on your new key. I was quoted $150CAD for a new flip key cut and programmed at my local guy
  4. Re: replacement key Fob
    Dec 2018
    cardiff
    No its not a keyless entry issue, its just the fob no longer functions
    as mentioned ive inspected inside and all (seems) fine the buttons work and light up the Fob
    but i cant seem to Sync or pair it despite trying numerous methods
  5. Re: replacement key Fob
    Mar 2019
    Canada
    That's exactly what's happening with my spare key. It lights up but just can't get it to connect to the car. Simply doesn't work no matter what I try.
    It's just a bad key.
  6. Re: replacement key Fob
    Jan 2009
    Birmingham
    36 Post(s)
    you need vcds to pair/sync it with the car
    Ross-Tech: VAG-COM: Remote Control Matching Info
  7. Re: replacement key Fob
    Dec 2018
    cardiff
    Quote Originally Posted by arman123 View Post
    is this a 100% certainty? As most can re-sync the Fob with basic key sync methods
    even using (used) Fobs, most guys on the US forums just buy Ebay Fobs swap the key over and re-sync using basic sync methods
    i cant see why my Fob cant do this, unless of course its (damaged) internally
  8. Re: replacement key Fob
    Jan 2009
    Birmingham
    36 Post(s)
    When I changed my battery in my fob years ago it lost sync I tried every method that i found online non worked the only thing that’s worked was Vcds if you fob is damaged then I don’t know if it would work are you sure it’s damaged? Can you see damage in the fob internally
  9. Re: replacement key Fob
    Dec 2018
    cardiff
    As previously mentioned, ive looked inside and all seems fine
    why i think it (may) be broken is just the fact that i cant get the Fob to sync with the car, its not a certainty, just trying to rule out possibilities
  10. Re: replacement key Fob
    Feb 2009
    Check if the oscillator fell off the CB - happened to a key on me once - light still came on the key but car would not recognise it. Discovered it was the oscillator when I used a frequency scanner and it got no reaction to the presses. resoldering it back on fixed the issue!
    you can get a key with the same code on Ebay and swap the insides and use VAG com to sync it up.
    W.
  1. Question Replacement Key
    By hshah in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 20-01-2017, 11:43 AM
  2. ABS replacement
    By Stevens71 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 12-06-2014, 12:14 PM
  3. Please Help a4 b6 b pillar crash sensor replacement (help with buying the replacement)
    By Train050 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2013, 10:35 PM
  4. CAT Replacement
    By jimjam in forum Golf MK4 - 1999 - 2004
    Last Post: 12-05-2009, 10:32 PM
  5. Replacement ECU?
    By bigun1972 in forum New Member Introductions
    Last Post: 02-05-2008, 10:46 AM
