Thread: Door wiring looms - colour coded wires - airbag, locks etc.
  1. Door wiring looms - colour coded wires - airbag, locks etc.
    Sep 2016
    London
    Does anyone have a diagram for which colour coded wires relate to which component in the door wiring looms?
    Especially for side impact sensor (have seatbelt/airbag fault warning lamp) and door locking module (got faulty locks, am aware that’s probably the lock/module/motor it’s self).
    The drivers door has had a few snapped wires (which I’ve rejoined) so I know there’s issues with that loom at least, common issue with golf mk5.
  2. Re: Door wiring looms - colour coded wires - airbag, locks etc.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Purple and brown appear to go to side impact sensor on both sides.
    Resistance of seat igniters is a well know problem for causing airbag light to come on. If you have VCDS you can look at resistance in real time I think - I recall using a pencil lead as a variable resistor to get a value that would allow me to turn off the warning by getting suitable resistors to bodge in from Maplin. I eventually got a cut-off loom from eBay long enough to remove the connection at bottom of B pillar by crimping instead. That fixed mine.
    On drivers side wires to motor locking unit are: yellow, blue/white, brown, white, purple. To contacts / switches: brown/yellow and green/white.
    Is that what you wanted?
  3. Re: Door wiring looms - colour coded wires - airbag, locks etc.
    Sep 2016
    London
    Quote Originally Posted by VAG-Abound View Post
    Yes that is what I want and thanks very much for proving the info, this is gonna be useful and great tip about testing seat igniters with VCDS.
  4. Re: Door wiring looms - colour coded wires - airbag, locks etc.
    Sep 2016
    London
    I should clarify about the wiring for the side impact sensors in the door, do you know which ones in particular they are or are they are? Brown and yellow?
  5. Re: Door wiring looms - colour coded wires - airbag, locks etc.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Unless I'm misreading something the sensors have purple and brown wires, and the supplying loom is also purple and brown on one side, red and brown on the other. What is making you think a yellow wire is involved? The yellow I mentioned was for door lock wiring.
    Is it front doors on a 4-door we're looking at?
  6. Re: Door wiring looms - colour coded wires - airbag, locks etc.
    Sep 2016
    London
    Thanks. The other side of what?
    Regarding yellow, not sure what my reason was.
  7. Re: Door wiring looms - colour coded wires - airbag, locks etc.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Other side of the car.
  1. Question 2005 Alhambra door wiring looms
    By LiamAlhambra in forum Alhambra
    Last Post: 13-07-2016, 08:55 PM
  2. Question Wiring looms
    By 5m4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2012, 10:43 PM
  3. Colour coded door mirror
    By zedmeister in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2008, 08:47 PM
  4. black colour coded door mouldings 5 door
    By madmonk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-09-2007, 05:01 PM
