Thread: 2017 3.L TDI Quattro COOLANT LEAK
Results 1 to 9 of 9
  1. 2017 3.L TDI Quattro COOLANT LEAK
    Jun 2020
    Cardiff
    I bought the car last year and am delighted with it apart from the fact that it is slowly losing coolant from the water pump housing. Luckily the car came with a warranty so I took it to my local independent VW specialist who took the front off and fitted a new water pump/ seals etc but the leak has not been fixed. All parts came from TPS and the garage has an excellent reputation so I strongly suspect that this is a known issue on this model but so far Audi are not owning up to anything. If any member has any advice or words of wisdom for me I would be delighted to hear from them!
  2. Re: 2017 3.L TDI Quattro COOLANT LEAK
    Feb 2012
    uk
    You say it's still leaking but is it the pump? or is it in the general area of the pump?
    I ask because some time back on an Audi V6 I had, a leak developed that took 6 months to pin down, it turned out to be a split ABS (plastic) non return valve that controlled coolant flow to the EGR valve cooling system. Located between the 2 inlet manifolds of the V-Six it was hard to locate/pin down because the Audi garage had to remove the inlet manifold to get to it. It leaked and flowed to the front and down the front casing appearing near the water pump and then soaking the sound proof mat at the engine base.
    When the engine was running it look like the water pump was spraying but it actually was flicking off the water running onto the front bearing...
    all the best...
    edit:
    At this site, is a picture of the valve, it's not your car or mine but it's the part that failed for me between the V inlets.
    Something to do with cooling the ERG valve using coolant system.
    vacuum system.Â*exhaust gas recirculation AUDI A6/S6/AVANT QU.
    Water Cooling Non-return Check Valve OEM for AUDI split on my V6
    2016 (B9) A4 Saloon S line 3.0 TDI quattro 272 PS tiptronic
    2012 (C7) A6 3.0 TDi Quattro S-Line, S-tronic, Sports Diff. 242PS
    2010 (C6) A6 3.0 TDi Quattro S-Line, Tiptronic, Le Mans. 233PS
  3. Re: 2017 3.L TDI Quattro COOLANT LEAK
    Jun 2020
    Cardiff
    Thank you for your helpful reply. I realise how difficult it is to pinpoint leaks. The garage that I took it to were confident that the leak was coming from the waterpump housing because they could see a pink antifreeze residue tracking from the leak. My suspicion now is that it could be the plastic waterpump housing which has warped due to age. I believe that the original housing might have been not up to the job and that Audi fixed quite a lot under warranty. I don't think that Audi have ever owned up to this issue but I was told that the waterpump housing had a new part part number in 2019..........
    I have booked the car into the local main dealer next week and see what they have to say about it. Cheers.
  4. Re: 2017 3.L TDI Quattro COOLANT LEAK
    Jun 2020
    Cardiff
    Well done noscream you were right on the money. I have just come back from the main dealer. They used an endoscope to see that the leak was coming from the coolant shut off valve. I don't expect that the parts will come to a lot but I understand that it is quite a substantial strip down to fix it since the inlet manifild has to come off........... At main dealer prices that comes to about £1500!
  5. Re: 2017 3.L TDI Quattro COOLANT LEAK
    Feb 2012
    uk
    I'm happy its helped you, the part is like a £10, labour is like 6-7hrs @ £160 plus all the other things they will replace getting to it (like gaskets, antifreeze etc).
    Generally the 3.0 is a solid engine but modern cars have so much compliance, the pipe maze for water, oil, gases and electrics has made a very complicated beast.
    I don't know how old your car is but I do recommend taking Audi extended warranty when the original one runs out, it's about £400-500 pa depending on excess.
    Some job costs are eye popping.
  6. Re: 2017 3.L TDI Quattro COOLANT LEAK
    Jul 2021
    Southampton
    I have the same issue with my 2016 3.L TDI quattro. Initial thoughts were water pump but following investigation that was fine. Can i ask, was it as expected around the £1500 total bill?
  7. Re: 2017 3.L TDI Quattro COOLANT LEAK
    Feb 2024
    Kent, UK
    Did you get your car fixed my 2016 one is losing coolant, how much was the vost of your repair. I am in kent any garage you would recomment or did you go to audi main dealer. Do main dealer charge for diagnosis
  8. Re: 2017 3.L TDI Quattro COOLANT LEAK
    Jun 2013
    Norwich, UK
    I realise that this thread is years old but just adding my experience for the benefit of anybody with the same problem.
    I have the same model as above and over three years experienced an increasing rate of coolant loss. Eventually having to top up weekly.
    The local Audi dealer was pretty unhelpful and wouldn't even look at it without a substantial diagnostics charge. Eventually took it to a very good independent in Norwich who immediately said that it was likely to be the seals on the EGR cutoff valve or one of the other coolant seals in the vee of the engine in the same area but no way to be sure without stripping everything out. I agreed to this and they went ahead and replaced the shut off valve and a few other possible seals. Said that they had been unable to pinpoint the exact source of the leak but were pretty confident that it was fixed. That was nearly a year ago and coolant level has not dropped since - so a successful repair.
    Total cost was £834
    1 2 0
  9. Re: 2017 3.L TDI Quattro COOLANT LEAK
    130 Post(s)
    1972 Post(s)
    Cheap part, hours of work.
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. Coolant leak through EGR valve V6 3.0 quattro TDI
    By Audijager in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2016, 03:21 PM
  3. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  4. Question 1999 A4 2.8 quattro 2.8 - coolant leak under inlet manifold
    By timmyp666 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2015, 05:49 PM
  5. Question Coolant leak 1998 A4 2.8 Quattro
    By joca in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-12-2008, 08:38 PM
