Thread: 2002 1.9PD no power, P1556 code.
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. 2002 1.9PD no power, P1556 code.
    Feb 2020
    Suffolk
    Hi All,
    I have a problem with my A6 i'm hoping someone with a better understanding of whats going on may be able to help me with it.
    Its a 2002 1.9 PD AWX engine code
    I have error code P1556 Charge pressure control negative. Its painfully slow, seems like there is no boost at all, ever. Now for the history of what's gone on.....
    I had the sticking VNT problem, it would go into limp mode, and be fine after a restart. it was occasionally, but got progressively worse.
    I removed the turbo and freed it off by working a spanner on the arm. Refitted but it didn't last long before it was stuck again, and was now smoking very badly and painfully slow!
    I bought a new cheap eBay turbo, complete unit including actuator. Fitted it, smoking has stopped but still painfully slow, like there is no boost at all.
    I've checked all the vacuum lines and they all seem ok. I borrowed vag com to do a turbo actuator test. It seems to be working ok, opening and closing freely.
    At idle the actuator pulls the arm fully up, if you pull the vacuum pipe off, the arm returns.
    I've checked all the charge pipes for leaks, pressurised them with an airline and all seem ok.
    I changed the fuel filter and tried a different MAF sensor as I had them with no change.
    The car is still painfully slow, no boost low down or seemingly anywhere!
    Hopefully this data I managed to log may be of some use.
    Any help would be much appreciated, as I don't really know what to do next.
    Thanks for reading
    Michael
    Last edited by Weedraker; 02-05-2020 at 06:26 PM. Reason: corrected engine code to AWX
  2. Re: 2002 1.9PD no power, P1556 code.
    Ireland
    Try to swap solenoid valves... turbo and egr valves, and see if its change..
    2001 allroad 2.5 AKE manual -gone
    2007 A6 Estate 2.0 BRE manual
  3. Re: 2002 1.9PD no power, P1556 code.
    130 Post(s)
    1972 Post(s)
    You mean AWX. Apply suction to the vacuum source hose off the servo feed pipe, you should not be able to draw air.
  4. Re: 2002 1.9PD no power, P1556 code.
    Feb 2020
    Suffolk
    I've tried sucking on the vacuum line, you cant draw any air. I've swapped the N75 valve, it made no difference. I've thoroughly checked the vac lines, and replaced a few. The actuator seems to be functioning ok when you run the test in vag com. When you first start the engine the actuator pulls the arm up to the stop.
  5. Re: 2002 1.9PD no power, P1556 code.
    Mar 2010
    Derry ireland
    63 Post(s)
    One does not suck vac lines or swap over valves its not professional all 0ne needs is a mity vac pump and a noid light to check the n75 which has to have 3 ports when energized vac travels
    between the top 2 ports when not energised vac gets dumpted via 1 and 3 ports the vac if checked at turbo actuator should read approx. 26/27 in/hg Regards mickeybo
  6. Re: 2002 1.9PD no power, P1556 code.
    130 Post(s)
    1972 Post(s)
    Quote Originally Posted by mickeybo View Post
  7. Re: 2002 1.9PD no power, P1556 code.
    Feb 2020
    Suffolk
    Hi, I have approx. 20 in/hg at the actuator. The N75 valve fully opens and closes the actuator under the vag com test.
  8. Re: 2002 1.9PD no power, P1556 code.
    130 Post(s)
    1972 Post(s)
    I would be doing a charge air system pressure test but you need the equipment to do this. This underboost code is nearly always a leak, either in the vacuum system or the boost charge air circuit such as a split turbo outlet hose (very very common on the AWX and AVF engine) or intercooler.
  9. Re: 2002 1.9PD no power, P1556 code.
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I had the same problem on the AWX I owned some years ago.
    It was the charge pressure hose, as Crasher suggests above.
    The hose leaves the turbo & wends it's way down to the intercooler via several 90 degree bends.
    On mine there was a split in the rubber pipe on the underside on one of the bends.
    It wasn't obvious but had left a trace of black oil sprayed down onto other components.
    Have a good look for telltale oil residue.
  10. Re: 2002 1.9PD no power, P1556 code.
    130 Post(s)
    1972 Post(s)
    Sometimes if you squeeze them your finger pops inside the split.
  1. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  2. Please Help p1556
    By willber6 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2010, 02:07 PM
  3. golf tdi S 90 BHP P1556 fault code, please help
    By gti203 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2008, 10:48 PM
  4. VW GOLF TDI S 90 BHP power loss P1556 fault code, please help
    By gti203 in forum New Member Introductions
    Last Post: 19-05-2008, 10:47 PM
  5. p1556 turbo pressure too low
    By milhouse in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-06-2006, 02:37 PM
