Thread: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
Results 1 to 10 of 11
  1. Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Hi, I’ve got an intermittent issue with the near side mirror indicator.
    Every now and then it will stop operating and the light bulb indicator comes on the dash briefly then disappears shortly afterwards (light on dash goes once operation of indicator resumes).
    I am suspecting bad wiring or the indicator LED PCB board is failing? Cracked solder?
    I don’t have access to the wiring diagrams for this so not sure of it’s operation and where the wires go
    to?
    Could it be bad wiring in the door jam?
    Or wiring to the window motor module?
    Any help would be appreciated.
  2. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    131 Post(s)
    1973 Post(s)
    The indicator is operated by the window controller and commanded by a CAN BUS signal from the central electrics whereas the other indicators are powered from the central electrics, do you know that the other left indicators are not acting the same way? Have you noticed the same behavior when arming/disarming the alarm?
  3. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    Jul 2018
    8 Post(s)
    Could it be damaged wiring in the door jam? I know this is a common problem....I replaced the whole loom on the driver side door when the fuel cap release stopped working....
    Hi Crasher....regarding your comments it appears to be isolated to the mirror indicator only....all other bulbs on the LHS front and rear are working ok....
    However I did have to replace the indicator bulb on the front LH headlight as the bulb went.....hoping this isn't anything suspcious....power surge / bad wiring?
    When operating the LH indicator via the stalk on the column all the LH indicator bulbs work apart from the wing mirror LED indicator.....sometimes it will spring back into life.....which could be due to
    going over bumps....moving the wiring / connections....suspecting this is probably the issue...
    I've not got another LHS indicator to test howveer I could probably use a RH which I have spare and see if that makes any difference?
    I did strip the LH indicator from the wing mirror to inspect the wiring and sprayed contact cleaner.....this seemed to remedy the issue....but not for long....
    I know unplugging and plugging in again can help remove any oxidation on the connectors...perhaps I should clean them up with emery?
  4. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    131 Post(s)
    1973 Post(s)
    Does everything else on the door work, I have had two instances now of 4 door Golf 5's shutting down everything on the left side doors front and rear.
  5. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    Jul 2018
    8 Post(s)
    The door lock no longer works but think that might be failed motor solenoid.
    From memory i think all the switch illumination still works on LHS.
    My 4 door golf only has front electric windows.
    I will check later if the rear door is locking or not on the LHS.
    What you thinking it might be? Failing CCM?
    Will post a VCDS auto scan also to see what codes are being registered.
  6. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    131 Post(s)
    1973 Post(s)
    Disconnect the battery overnight.
  7. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    Jul 2018
    8 Post(s)
    Ok I will give disconnecting the battery a go but I am doubtful as have had the battery disconnected recently and made no difference.
    The issue is intermittent....not sure where to go next.
  8. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    Jul 2018
    8 Post(s)
    Scan for the car is here......
    Not showing any codes for the mirror indicators though? Was expecting an intermittent code to confirm a wiring issue.....
    Any ideas?
    Code:
    Monday,27,April,2020,13:49:05:33544VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 20.4.0.1 (x64)
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W096975   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W096975   Mileage: 340060km-211303miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 BA    HW: Hardware No
       Component: MED9.5.10       G00 5697
       Revision: 00000000    Serial number: VWZ7Z0D9331576
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 63C1C201A2D6B09E7F-8036
    4 Faults Found:
    16474 - Valve for Fuel Metering (N290)
                P0090 - 004 - Open Circuit - Intermittent
    19490 - Intake Air Temperature Sensor 2 (G299)
                P3034 - 002 - Signal too Large - Intermittent
    18726 - Fuel Pressure Regulator Valve (N276)
                P2294 - 004 - Open Circuit - Intermittent
    16396 - Bank 1: Camshaft A (Intake)
                P0012 - 008 - Advance Setpoint not Reached (Over-Retarded) - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A7F5F6575DC91560C-806E
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   080 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C7DB1551E4C5B698-8032
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000514812
       Coding: E48D0F0600041800001400001400000000
       VCID: 3779465146CE8C3EF3-8062
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    5 Faults Found:
    01064 - Terminal 58d; Interior Dimming
    00978 - Lamp for Low Beam; Left (M29)
                010 - Open or Short to Plus - Intermittent
    01049 - Supply Voltage Term 50
                006 - Short to Plus - Intermittent
    00988 - Lamp for Brake Light; Right (M10)
    01493 - Bulb for Blinkers; Front Left (M5)
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08P0VC
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A5F6F25857C21D67C-807E
       Subsystem 1 - Serial number: 6332MSME5D7E1002
       Subsystem 2 - Serial number: 6342MSME57340A02
       Subsystem 3 - Serial number: 6351HSME43485801
       Subsystem 4 - Serial number: 6361HSME5D0F5901
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 306B7D4DA3A05B06B2-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3554
       Coding: 0000401
       Shop #: WSC 00218 210 03908
    1 Fault Found:
    00771 - Fuel Level Sensor (G)
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100104128EF35
       Coding: 3D0F0340070003
       VCID: 27599611966E1CBE63-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3554
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    1 Fault Found:
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2E576335B9944DF6A0-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81E802087F2D8505485BC61000
       Shop #: WSC 00218 210 08203
       VCID: 7BF19A613A66685E57-802E
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    2 Faults Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
    00931 - Locking Module for Central Locking; Rear Right (F223)
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316D7849A8AA520EBD-8064
    2 Faults Found:
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
                008 - Implausible Signal
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D556439B49236EE99-8078
    End-------------------------(Elapsed Time: 01:36)--------------------------
  9. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    131 Post(s)
    1973 Post(s)
    These could be spiking the door controller.
    01553 - Motor for Central Locking; Passenger Door (V57); Lock 012 - Electrical Fault in Circuit
    00929 - Locking Module for Central Locking; Front Passenger Side (F221) 008 - Implausible Signal
  10. Re: Golf Mk5 FSI (BAG Engine Code) - Intermittent Mirror indicator operation
    Jul 2018
    8 Post(s)
    Replace the door locking module? Will check wiring first in door jam and see if any breaks.....not sure I want to fork out for a new harness!
  1. Please Help 2004 1.9 tdi engine code bkc. Intermittent starting issues
    By Mickyroo in forum Golf MK5 - 2004 - 2009
    Last Post: 29-05-2015, 10:03 PM
  2. Replies: 1
    Last Post: 06-03-2015, 01:59 PM
  3. Question 58 reg Golf TSI (mk5) wing mirror indicator/reflector
    By bromine in forum Golf MK5 - 2004 - 2009
    Last Post: 29-03-2012, 10:18 PM
  4. Golf: dark indicator-in-mirror lenses
    By cartwrim in forum Chat - Anything with wheels
    Last Post: 06-10-2008, 09:58 AM
  5. 2008 golf drivers mirror glass and indicator fitting help :)
    By BICCUS1 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-04-2008, 08:22 PM
