Thread: Car won't start - Immobiliser active
Results 1 to 10 of 12
  1. Car won't start - Immobiliser active
    Mar 2006
    Berkshire
    My key broke at the hinge bit so the blade and the fob were in two bits. My dad had an old vw golf mkv key fob, so put the old key blade on the new top half of the fob and joined it with the bottom half of the old fob.
    Now my car won't start and has "immobiliser active safe" on the display. The fob still unlocks and locks the car.
    What do I need to do fix this, please help as I need the car to get to work
  2. Re: Car won't start - Immobiliser active
    Mar 2018
    GB
    19 Post(s)
    The key needs to be coded to the immobiliser, at present that will be difficult as nothing is open.
    Sent from my SM-G950F using Tapatalk
  3. Re: Car won't start - Immobiliser active
    Mar 2006
    Berkshire
    could this be done on the carista app?
  4. Re: Car won't start - Immobiliser active
    Mar 2018
    GB
    19 Post(s)
    Ask Google I don't know, sorry.
  5. Re: Car won't start - Immobiliser active
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by apache24uk View Post
    Look inside your old fob (or hold it close to ignition), aswell as check the area where it broke for a missing chip (transponder). Transponder chip can fall out of the case when opened.
  6. Re: Car won't start - Immobiliser active
    131 Post(s)
    1973 Post(s)
    No Carista will not do this nor will VCDS. The only correct way is to use the VW dealer software ODIS with GEKO security access and the VAG system in Germany does the job online, you can’t see any info such as codes any more, the SKC as it was known. There are aftermarket system such as VAG TACHO which professional key specialists use but it is very hit and miss which is why I went through the hurdles of getting ODIS approval, and it is still hard work programming in things like used instruments. As the other chap said the best way for you is to swap over the chip from one key to another. These are tiny glass vials about the size of a grain of rice housed in the lower section of the key and are extremely fragile, if you break it you will need a new chip programming into the instruments.
  7. Re: Car won't start - Immobiliser active
    Mar 2017
    Nottingham
    11 Post(s)
    Them little glass chips will be glued in just put a hair dryer on it for two minutes an put it into new key or just put old key shell in glovebox and you should be good to go
  8. Re: Car won't start - Immobiliser active
    Mar 2016
    Minervois, France
    54 Post(s)
    I had new keys cut and coded for my 1998 A4, but the specialist who did the job needed an original key, with functioning chip, which his equipment could copy.
    He had one device to read the code and copy to a new chip, and a machine which automatically cut the key from digital information (not jut a key copier as found in hardware shops).
    He previously tried to get the key info' from the ECU, before realising that my car used an older coding system.
    He said that VAG could no longer provide codes for older cars, as they had been lost/destroyed.
    The chip in my keys is in the plastic top part of the key, there is no hinge or separate fob, and the chip falls out if the plastic part is opened.
    I do not have remote locking. The button on the plastic bit operates a little LED, which is of no real use to find the keyhole or anything else, but was proably an expensive extra when the car was made
    EDIT: I hope you didn't throw your old fob away, as did an unfortunate French owner on one of the forums here
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  9. Re: Car won't start - Immobiliser active
    131 Post(s)
    1973 Post(s)
    Yes, yours will have the earlier, very sturdy, plastic chip, the later glass vial ones look like an insect pupa.
  10. Re: Car won't start - Immobiliser active
    Mar 2006
    Berkshire
    Thanks for the replys. Found the transponder
  1. Question Immobiliser Active + Glowplug Flashing
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-03-2013, 08:39 AM
  2. Question Key fob wont start car, immob active ???
    By unclespevie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2012, 03:34 PM
  3. Please Help Immobiliser Active!
    By johnnypbristol in forum Jetta MK3 - 2005 - 2013
    Last Post: 12-08-2010, 10:02 AM
  4. mk4 1.6 immobiliser? won't start!
    By zye3153 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2009, 06:08 PM
  5. over active immobiliser
    By richard01276 in forum Audi A4 - Archive Topics
    Last Post: 11-01-2008, 08:38 PM
