Thread: mk4 steering noise on full lock
Results 1 to 10 of 15
  1. mk4 steering noise on full lock... HELP...HELP
    Sep 2007
    Hi everyone.
    I have a golf v6 4motion 51 plate with 93k on the clock, can anybody out there with their vw head on shed any light on this problem for me, Best way i can explain it is, empty car park full lock on either left or right makes no difference, Drive car slowly in circles and i get a rubbing scraping like noise ,I thought tyres might be catching on plastic inner arches, (that type of sound) but i have definately ruled this out, the noise will only happen when car is driven, If i coast it with full lock and no engine load the noise dissappears, The thoughts i have now are that it might be something to with the clutch or the steering rack but i'm really struggling. Its also difficult to pin-point exactly where the noise is coming from sometimes think its from the back of car but that doe'snt seem to make much sense. by the way suspension is all o.k new springs were fitted 3 months ago.
  2. Re: mk4 steering noise on full lock
    Apr 2007
    N.Ireland
    Might be a problem with a CV joint or a CV joint boot, although this problem would cause more of a clicking sound at full lock rather than a scraping sound.
  3. Re: mk4 steering noise on full lock
    neileg Guest
    When the steering is on full lock against the stops, there's a valve in the steering pump that opens to stop you damaging the pump. I reckon that's the noise you are hearing. With the engine off there's no pump action so no noise.
  4. Re: mk4 steering noise on full lock
    Sep 2007
    Thanks Neil/Chris, When i say there is no noise when coasting i mean the engine is still running but when i put the clutch in (disengage) whilst turning in a circle the noise disappears.....let the clutch out and it returns,
    can you help further....cheers Bob
  5. Re: mk4 steering noise on full lock
    Mar 2007
    nr Gloucester
    I think I had the same problem as you. If it is, then the noise was coming from the alternator belt tensioner. The garage originally thought it was the steering rack but on closer inspection was this belt tensioner.
    The noise wouldn't be so bad on full lock if I revved the car more, but if didn't then the noise would be really loud.
    From memory was about £130 to fix.
    Ad
  6. Re: mk4 steering noise on full lock
    Sep 2007
    thanks Ad, but i can't see how the alternator tensioner can be affected by the steering being on full lock mate, can anyone offer any more suggestions to this problem..... cheers Bob.
  7. Re: mk4 steering noise on full lock
    Feb 2007
    kernow massive
    Quote Originally Posted by mk1 Bob View Post
    geezer i think your hearing what all of us hear in our mk4's when we put it on full lock... just don't do it.. you can wreck it.. but if in doubt ask 'crasher' he's the boy or the man rather.
  8. Re: mk4 steering noise on full lock
    Dec 2007
    I think I have the same noise as you. I think it is normal and caused by the 4 wheel drive system creating a slight drag?
  9. Re: mk4 steering noise on full lock
    i have the same problem and only happens wen movin forward full lock. its like a droaning/rubbing noise annoying to say the least
  10. Re: mk4 steering noise on full lock
    Jun 2009
    Liverpool
    So should you just live with the noise or is it a fault that needs seeing to?
  1. Steering noise
    By Mav2006 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-12-2007, 03:37 PM
  2. MK3 Steering noise...Help!
    By tot in forum Golf MK3 - 1993 - 1999
    Last Post: 07-10-2007, 10:43 PM
  3. How easy or difficult to...change a steering wheel (full descriptive titles help!)
    By A6_JAck in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-09-2007, 11:35 AM
  4. Polo - strange noise when turning/full lock right
    By Dreamertae in forum Polo - Derby - Lupo - Fox
    Last Post: 18-07-2007, 09:14 PM
  5. mk4 golf front clunk on full lock then front rattle over bumps
    By jwexqm in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2007, 11:04 PM
