Thread: 2006 Audi A6 Allroad Suspension Problem
  1. 2006 Audi A6 Allroad Suspension Problem
    Oct 2009
    Essex
    I'm hoping there's another tech on here who can point me to the area I need to be checking, as this car has given me a few headaches over the past year! Crasher if your around your valued opinion would be really appreciated m8.
    The compressor receiver blew up when the relay gave in because the cut out stuck on, so both the compressor and of course the relay were changed. The valve control module has also been replaced.
    What the latest issue is the rear O/S suspension drops over night but pumps up to level when the car is run in the morning, the amber level control warning lamp flashes when the car is being driven. I suspect it could be the rear air spring/ bag that could have a small leak but for some reason my instincts are telling me not.
    The owner wants to the car to last him another 2 years, so when you see the scan please ignore all the faults flagging up its just the suspension problem that needs to be dealt with!
    Thanks in advance
    Dave
    Tuesday,03,March,2020,14:36:11:55488
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 19.6.2.2
    Data version: 20200210 DS308.0
    Ross-Tech: Home
    Dealer/Shop Name: Airmec Engineering
    Workshop Code: 444 12345 012345
    VIN: WAUZZZ4F87N001505 License Plate:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 42 46 47 4F 52 53
    55 56 61 62 6D 72 76 77
    VIN: WAUZZZ4F87N001505 Mileage: 209870km-130407miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    34-Level Control -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-BPP.clb
    Part No SW: 4F1 910 401 G HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000AG 0010
    Revision: --H02--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: 2142FF98F8112A478A-8074
    6 Faults Found:
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 209717 km
    Time Indication: 0
    Date: 2020.02.26
    Time: 04:02:06
    Freeze Frame:
    RPM: 945 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 24.1 %
    Temperature: 4.5°C
    005659 - Glowplug for Cylinder 2 (Q11)
    P161B - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 209717 km
    Time Indication: 0
    Date: 2020.02.26
    Time: 04:02:06
    Freeze Frame:
    RPM: 945 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 24.1 %
    Temperature: 4.5°C
    005660 - Glowplug for Cylinder 3 (Q12)
    P161C - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 209717 km
    Time Indication: 0
    Date: 2020.02.26
    Time: 04:02:06
    Freeze Frame:
    RPM: 945 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 24.1 %
    Temperature: 4.5°C
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 209717 km
    Time Indication: 0
    Date: 2020.02.26
    Time: 04:02:06
    Freeze Frame:
    RPM: 945 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 24.1 %
    Temperature: 4.5°C
    005662 - Glowplug for Cylinder 5 (Q15)
    P161E - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 209717 km
    Time Indication: 0
    Date: 2020.02.26
    Time: 04:02:06
    Freeze Frame:
    RPM: 945 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 24.1 %
    Temperature: 4.5°C
    005663 - Glowplug for Cylinder 6 (Q15)
    P161F - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 209717 km
    Time Indication: 0
    Date: 2020.02.26
    Time: 04:02:06
    Freeze Frame:
    RPM: 945 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 24.1 %
    Temperature: 4.5°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F1 910 156 T HW: 09L 927 156 A
    Component: AG6 09L 2.7 TDI 132 0010
    Revision: --H01--- Serial number: 4176731
    Coding: 0000002
    Shop #: WSC 02325 785 00200
    VCID: 356A3BC85C99B6E746-8060
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.clb
    Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
    Component: ESP 8.0 quattro H05 0040
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0016776
    VCID: 64CCB68CA7837F6F21-8030
    Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000415856
    Coding: 0000151
    Shop #: WSC 00551 210 84039
    VCID: 63CEB590A28D7857D8-8036
    Subsystem 1 - Part No: 4F0 910 131 G
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H27 0080
    Subsystem 3 - Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H45 0060
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
    Part No SW: 4F0 910 731 D HW: 4E0 035 729
    Component: Interfacebox H43 2830
    Revision: 00000000 Serial number: 350DM067671119
    Coding: 0003002
    Shop #: WSC 02335 785 00200
    VCID: 234EF590E20D385798-8076
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0050
    Subsystem 2 - Serial number: 00000000401014
    Subsystem 3 - Serial number: 0126.04.060000000100010718’
    Subsystem 4 - Serial number: 010718’
    1 Fault Found:
    01327 - Control Module for Parking Aid (J446)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 29
    Reset counter: 143
    Mileage: 207501 km
    Time Indication: 0
    Date: 2019.11.25
    Time: 20:58:00
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 HW: 4F2 820 043 M
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000030 Serial number: 00000030118725
    Coding: 0001302
    VCID: 5BBE8D709AFD409790-800E
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 D HW: 4F0 907 279
    Component: ILM Fahrer H15 0190
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    VCID: 2A5018B48527E91FDB-807E
    Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH12 0090
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8106399
    Shop #: WSC 00000 000 00000
    VCID: 1C3CCE6CDF7307AF59-8048
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0ECEEC
    Coding: 0013381
    VCID: 2952E7B88021E207D2-807C
    Subsystem 1 - Serial number: 6332CSME0F3F097DN
    Subsystem 2 - Serial number: 6342CSME0E3A6609A
    Subsystem 3 - Serial number: 6352QSME0E3C4C3F/
    Subsystem 4 - Serial number: 6362QSME0E12246BI
    Subsystem 5 - Serial number: 63734SME09484B0B5
    Subsystem 6 - Serial number: 63834SME0B4718695
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H07 0230
    Revision: 00H07000 Serial number: 90025061110579
    Coding: 0102142
    Shop #: WSC 02323 785 00200
    VCID: 66C8AC8451BF0D7F3F-8032
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    1 Fault Found:
    01749 - Switch for Tiptronic in Steering Wheel (E439); Down
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 118
    Mileage: 209858 km
    Time Indication: 0
    Date: 2020.03.02
    Time: 19:16:32
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
    Component: KOMBIINSTR. M73 H17 0070
    Revision: 00400000 Serial number: 58+36FL46
    Coding: 6249443
    Shop #: WSC 12345 444 12345
    2 Faults Found:
    00438 - Fuel Supply Sensor 2 (G169)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 7
    Fault Frequency: 19
    Reset counter: 133
    Mileage: 201890 km
    Time Indication: 0
    Date: 2019.06.13
    Time: 14:41:02
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 19
    Reset counter: 133
    Mileage: 201890 km
    Time Indication: 0
    Date: 2019.06.13
    Time: 14:41:02
    Address 19: CAN Gateway Labels:. 4L0-910-468.clb
    Part No SW: 4L0 910 468 HW: 4L0 907 468
    Component: J533__Gateway H06 0040
    Revision: 00H06000 Serial number: 0900B063308203
    Coding: F551BE7F303206
    Shop #: WSC 00551 210 91512
    VCID: 6CDCDEAC4F53372F69-8038
    Address 34: Level Control Labels: 4F0-910-553.clb
    Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
    Component: J197 LUFTFEDER H17 0060
    Serial number: 00619000248900
    Coding: 0000210
    VCID: 2240F094FD17315F93-8076
    1 Fault Found:
    02645 - Valves for Level Control System
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 158
    Mileage: 209716 km
    Time Indication: 0
    Date: 2020.02.25
    Time: 19:02:49
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
    Component: MNS ECE H47 0850
    Revision: 00000000 Serial number: 364D-067554389
    VCID: 3B7E2DF07ABD6097B0-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00-00000
    Coding: 0020026
    Shop #: WSC 02327 785 00200
    VCID: 2C5C1EAC8FD3F72F29-8078
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01012841090000
    Coding: 3285755
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H10 0350
    Revision: 41S00001 Serial number: 02604060263326
    Coding: 0000103
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000229224
    Coding: 0001103
    VCID: 5EB8846489EF55BFF7-800A
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00-00000
    Coding: 0020026
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 A HW: 4F0 907 801
    Component: EPB CA3C0040 H03 0040
    Revision: --H03---
    Coding: 0000521
    Shop #: WSC 02324 785 00200
    VCID: 1E38C464C96F15BFB7-804A
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
    Component: AFS 1 H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000017
    VCID: 2854E2BC9B2BDB0FCD-807C
    Subsystem 1 - Part No: 4F0 941 329 B
    Component: AFS-Modul links H02 0020
    Subsystem 2 - Part No: 4F0 941 329 B
    Component: AFS-Modul rechtsH02 0020
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 M HW: 4F0 035 541 E
    Component: TUNER EU/US/RDW H42 0570
    Revision: 00000000 Serial number: 352DI067642133
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000019867
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2604280748
    Coding: 344630393135313035442056413032363034323830373438
    Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0019498
    VCID: 2E5814A4B9CF853F07-807A
    Address 6D: Trunk Elect. Labels: Redir Fail!
    Part No SW: 4F9 910 591 HW: 4F9 827 851 D
    Component: ValeoHeckdeckel H20 0280
    Revision: --H20001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    Subsystem 1 - Part No: 4F9 910 592
    Subsystem 2 - Serial number: E5030100B
    Subsystem 3 - Serial number: RD25.04.06--H20001000B0040’
    Subsystem 4 - Serial number: 0B0040’
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0019498
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 E HW: 4F0 919 283 E
    Component: Parkhilfe 8-Kan H12 0030
    Revision: 00H12000 Serial number: 11820611602685
    Coding: 0201416
    Shop #: WSC 131071 1023 2097151
    VCID: 2648EC84913FCD7FFF-8072
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 H HW: 4E0 862 335
    Component: Handyvorb2 H13 0700
    Revision: 00000000 Serial number: 00000007628446
    Coding: 0010920
    VCID: 2756E1809635D477C4-8072
    End-------------------------(Elapsed Time: 03:31)--------------------------
    There's a fine line between genius and insanity!
  2. Re: 2006 Audi A6 Allroad Suspension Problem
    Jul 2013
    76 Post(s)
    You may have levelling valve issue.
    one maybe broken
    read this first if you have not done so.
    02645 - Ross-Tech Wiki
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: 2006 Audi A6 Allroad Suspension Problem
    Oct 2009
    Essex
    Hi Dan the leveling control unit was replaced last year, but I guess its worth checking out again with fit an old unit I have.
    Trouble is with this air suspension its getting a bit old now so other possibilities start to enter the equation, such as a small puncture in the rear air spring as this old bus sinks down over night on the rear O/S!
  4. Re: 2006 Audi A6 Allroad Suspension Problem
    Jul 2013
    76 Post(s)
    Have you confirmed that the levelling sensors are working correctly?
    Dan
  1. Audi A6 Allroad 3.0 TDI 2007 - Air Suspension problem
    By stewart71 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-07-2017, 07:35 AM
  2. Question Audi A6 Allroad Suspension problem
    By magor226 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-03-2017, 01:45 AM
  3. A6 Allroad 2006 rear suspension dropping
    By mhobson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-11-2016, 10:01 PM
  4. Question suspension allroad 2006 estate
    By chris.d in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-05-2015, 09:58 PM
  5. Audi Allroad Suspension Problem
    By oraclenet in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-09-2008, 10:15 PM
