Thread: Coolant top up help please
Results 1 to 10 of 12
  1. Coolant top up help please
    Dec 2019
    Buckie
    Hi all,
    My 3.0 BITDI’s coolant top up light came on today and I read my manual for which type of coolant I require.....
    Manual states G12/G13
    My dilemma is the local places near me only have ‘Prestone’ coolant and it has no mention of G12/G13 in it.
    Anyone know if this is safe to use at all or will it not mix properly and cause sludge and corrosion that I’ve read rumours of online?
    I require about 0.5-0.75L I think to top up with.
    Cheers.
  2. Re: Coolant top up help please
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    It's fine, totally compatible.
    1 1 0
  3. Re: Coolant top up help please
    Dec 2019
    Buckie
    Thanks for your help
  4. Re: Coolant top up help please
    Aug 2018
    Swindon
    22 Post(s)
    According to this site ...... its guaranteed to mix with anything !!
    Prestone Coolant Antifreeze | Prestone Car Maintenance
    2014 Audi A6 Allroad (C7, 245bhp)
  5. Re: Coolant top up help please
    Dec 2019
    Buckie
    I did read that but have also read online that G12 should never be mixed with anything as it causes a jelly substance with others so thought I’d ask if anyone had any opinions here.
    Next to find out why I needed 1ltr of coolant with no obvious leaks???
  6. Re: Coolant top up help please
    Oct 2019
    Peterborough, England
    23 Post(s)
    I'd order some G12/13 for delivery and only use that.
    I wouldn't stick the 'generic' stuff in at all
    Garages and service stations should have G12/G13.
  7. Re: Coolant top up help please
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Get some from you local TPS. Its not very expensive and its available in pre mixed or concentrate.
    1 1 0
  8. Re: Coolant top up help please
    Dec 2019
    Buckie
    Well 3 weeks on and roughly 4/500 miles later I’ve noticed the coolants sitting below the min level again.
    No warning messages yet as it must be above the sensors still.
    Nothing on the driveway and no obvious signs of water anywhere.
    Anyone know of any common issues or places to recheck again in daylight?
    Thanks in advance
  9. Re: Coolant top up help please
    Dec 2016
    Edinburgh, Scotland
    15 Post(s)
    Have you checked right down on the bottom corners of the radiator for crystallised granules? They may look like coloured sand. I have seen a few cars in the past develop leaks down in the lowest and dampest corner spots.
  10. Re: Coolant top up help please
    Jan 2013
    114 Post(s)
    Probably a waste of time but have you checked your oil for signs of emulsification?
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. Replies: 6
    Last Post: 29-11-2018, 01:41 PM
  3. Replies: 6
    Last Post: 30-08-2017, 09:04 PM
  4. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  5. Car Plan Red Advance Anti-Freeze & Coolant Supplied as G12++ Coolant
    By Vindictive in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 04:12 AM
