Thread: Vcds
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Vcds
    Jan 2020
    Surrey
    Hi everyone I'm in desperate need of help I have VW tiguan 2011 and had a friend come over with apparently legit ross tech vcds to change my display from kph to mph but he has now made it show tons of error codes and just found out we're fake clone vcds cable now won't answer his phone and now house bound with children as car won't even start please anyone local that can help me I'm in Guildford Surrey
  2. Re: Vcds
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    I understand why you've made multiple posts, but it makes it hard to build a consolidated set of replies and advice.
    I'm assuming some of the core coding on dash cluster or other component has been trashed. Even if I came to visit I'd have no idea what coding would fix it, unless your friend happened to leave a copy of the "before" settings.
    If someone knows what default coding would get it working again I'd try.
  3. Re: Vcds
    Jan 2020
    Surrey
    hi i have the laptop that he used here would that have it on.
  4. Re: Vcds
    Jan 2020
    Surrey
    I have the laptop here that was used so should have it on would be amazing if you could help me.
    Thank you
  5. Re: Vcds
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    So you used genuine VCDS software with a fake cable? Maybe a hacked genuine VCDS that only works with that cable?
    Either way normal thing would have been to do a full scan and save the results, or at least of the modules you were going to adjust. This wiuld then keep a record of the original settings to revert to if anything was odd afterwards. Do you have a saved scan? It would usually end up in the LOGS folder where VCDS is installed.
    You have other replies in your other threads from people closer to you. Easier if they try first. Happy to try and guide them remotely, although its a problem I've never fixed before.
  6. Re: Vcds
    Jan 2020
    Surrey
    Yes he did a full scan first and they were hacked copy i believe so should have a record of the first scan ok will see if anyone more local can help.
    many thanks
  7. Re: Vcds
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    If you find that file, open it up and cut / paste the bit that relates to instrument cluster here it may encourage folk that they can help you.
    Not wanting to cause unnecessary anxiety, but are you confident about the car's history. Seems odd yhat a UK car would be showing km, and could be a sign of hacked cluster to hide mileage or stolen car (immobiliser is in cluster I think). So it could have been petfectly good hacked VCDS () confounded by hacked car.
  8. Re: Vcds
    Jan 2020
    Surrey
    Friday,24,January,2020,18:22:25:00007
    VCDS Version: 18.9.0.2 (x64)
    Data version: 20180927 DS296.0
    Ross-Tech: Home
    VIN: WVGZZZ5NZBW087589 License Plate:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 56 62 72
    77
    VIN: WVGZZZ5NZBW087589 Mileage: 52640km-32708miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 FA HW: 03L 907 309 R
    Component: R4 2.0l TDI H23 9979
    Revision: 42H23--- Serial number: 00000000000000
    Coding: 00250012040700080000
    Shop #: WSC 00066 210 00000
    ASAM Dataset: EV_ECM20TDI01103L906018FA 003012
    ROD: EV_ECM20TDI01103L906018ET.rod
    VCID: 6ED378B9B197023A37-803A
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
    Part No SW: 0BH 300 011 F HW: 0BH 927 711 C
    Component: DSG DQ500-7A H04 1407
    Revision: 00H04V01
    Coding: 0014
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMDQ500021 001001
    ROD: EV_TCMDQ500021.rod
    VCID: 2541479524E1016286-8070
    Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
    Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q
    Component: J104 C4 450 V22C 0006
    Revision: --H28--- Serial number: 00000003638009
    Coding: 0031047
    Shop #: WSC 01324 020 00200
    VCID: 39799BE570599582D2-806C
    Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
    Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
    Component: AC Manuell H17 0202
    Revision: 00012001
    Coding: 0000000002
    ASAM Dataset: EV_Climatic A01005
    ROD: EV_ClimaBasis_VW36.rod
    VCID: 3D718FF5AC71A9A2FE-8068
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
    Component: BCM PQ35 M 011 0046
    Revision: BC011001
    Coding: 48180A3B8025F1C040080080B400012443513088536D85605C 8000000040
    VCID: 3B7581EDBA65A792C0-806E
    Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
    Component: Wischer 14011 012 0203
    Serial number:
    N2955119 °203!
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 250111 05 54 0403
    Coding: 03304D
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Coding: 000000
    Subsystem 4 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    Coding: 000000
    Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
    Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
    Component: PARKHILFE PLA H08 0116
    Revision: -------- Serial number: 13991101359178
    Coding: 109103
    VCID: 489FEE21FBB3FC0A5D-801C
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
    Component: J234__201 VW10 HI 1918
    Revision: 22014000 Serial number: 003K0PSGQ3XP
    Coding: 0012337
    VCID: 4C97D2312FCB102A79-8018
    Subsystem 1 - Serial number: 6332MTS668053530
    Subsystem 2 - Serial number: 6342MTS643793520
    Subsystem 3 - Serial number: 6351HTS613F7M9KJ
    Subsystem 4 - Serial number: 6361HTS6JN18M9KR
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 521 AN HW: 5K0 953 569
    Component: LENKS.MODUL 009 0136
    Revision: FF010039 Serial number: 20110102200376
    Coding: 5880040000
    ASAM Dataset: EV_SMLSNGVOLWS A01004
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 78FF5EE1C3D34C8AED-802C
    Part No SW: 5N0 920 972 A HW: 5N0 920 972 A
    Component: KOMBI H20 0420
    Coding: 410F01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 3169A3C560295DC26A-8064
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 C HW: 1K0 907 951
    Component: J533 Gateway H37 0614
    Revision: H37 Serial number: 190111F2001803
    Coding: 356003
    VCID: 306FA6C1632354CA65-8064
    Address 22: AWD Labels: 0AY-907-554-V1.clb
    Part No SW: 0AY 907 554 D HW: 0AY 907 554 D
    Component: Haldex 4Motion 0042
    Coding: 0000005
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H20 0420
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6ADB74A98D7FEE1A6B-803E
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
    Component: Tuer-SG 009 2112
    Coding: 0000700
    VCID: 366390D941477AFA3F-8062
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 5N0 909 144 M
    Component: EPS_ZFLS Kl. 203 3201
    Revision: 00H20000
    Shop #: WSC 01324 785 00200
    VCID: 3B7581ED7A65A792C0-806E
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
    Coding: 0000700
    VCID: 377D9DDD464D83F224-8062
    Address 53: Parking Brake Labels: 3AA-907-801.clb
    Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
    Component: J540 EPB4 VW-55183 0007
    Revision: H18 Serial number: 00000000136212
    Coding: 0023057
    VCID: 3365A9CD52356FD218-8066
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 HW: 3C8 035 195
    Component: RCD510 H14 5025
    Revision: -----11S Serial number: VWZ4Z3K1158785
    Coding: 0500040004
    VCID: 65C107956C61C16246-8030
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 44
    Mileage: 52645 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 19:20:28
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
    Component: Tuer-SG 007 2102
    Coding: 0000144
    Shop #: WSC 01324 020 1012552
    VCID: 387F9EE14B538C8A2D-806C
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
    Coding: 0000144
    Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
    Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
    Component: TELEFON H05 0440
    Revision: 1B001001 Serial number: 00007668906382
    Coding: 0A01000000010101
    ASAM Dataset: UHVNA A01007
    ROD: UHVNA.rod
    2 Faults Found:
    13635840 - Supply voltage
    U1011 00 [001] - Voltage too Low
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Not Confirmed - Tested Since Memory Clear
    13893632 - Function Restricted due to Insufficient Voltage
    U1400 00 [001] - -
    End-------------------------(Elapsed Time: 03:02)--------------------------
    Controller Software Versions:
    ECU 1 = Engine 9979
    ECU 2 = Auto Trans 1407
    ECU 3 = ABS Brakes 0006
    ECU 4 = Auto HVAC 0202
    ECU 5 = Cent. Elect. 0046
    Sub ECU 5 > 1 = Cent. Elect. 0203
    Sub ECU 5 > 2 = Cent. Elect. 0403
    Sub ECU 5 > 3 = Cent. Elect. 0104
    Sub ECU 5 > 4 = Cent. Elect. 9005
    ECU 6 = Park/Steer Assist 0116
    ECU 7 = Airbags 1918
    ECU 8 = Steering wheel 0136
    ECU 9 = Instruments 0420
    ECU 10 = CAN Gateway 0614
    ECU 11 = AWD 0042
    ECU 12 = Immobilizer 0420
    ECU 13 = Door Elect, Driver
    ECU 14 = Steering Assist 320
    ECU 15 = Door Elect, Pass. 2
    ECU 16 = Parking Brake 0007
    ECU 17 = Radio 5025
    ECU 18 = Door, Rear Left 210
    ECU 19 = Door, Rear Right 21
    ECU 20 = Telephone 0440
  9. Re: Vcds
    Jan 2020
    Surrey
    Friday,24,January,2020,18:43:59:00007
    Ross-Tech: Home
    77
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Cannot be reached
    Address 15: Airbags
    Cannot be reached
    Cannot be reached
    Coding: 110F01
    1 Fault Found:
    U1011 00 [008] - Voltage too Low
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 52645 km
    Date: 2020.01.24
    Time: 19:23:23
    Coding: 356003
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 52645 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 19:22:49
    Address 22: AWD
    Cannot be reached
    Coding: 000000
    Cannot be reached
    Cannot be reached
    Address 46: Central Conv.
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Coding: 0500040004
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 52645 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 19:20:28
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 52645 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 19:21:34
    Cannot be reached
    Cannot be reached
    ROD: UHVNA.rod
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 44
    Mileage: 52645 km
    Date: 2020.01.24
    Time: 19:21:54
    U1400 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 52645 km
    Date: 2020.01.24
    Time: 19:21:52
    End-------------------------(Elapsed Time: 02:29)--------------------------
    ECU 1 = Engine 9979
    ECU 11 = AWD 0042
    ECU 17 = Radio 5025
    ECU 18 = Radio 5025
    ECU 21 = Telephone 0440
    and this is the one with errors
  10. Re: Vcds
    Jan 2020
    Surrey
    is this what i needed to post
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. vcds
    By mogsy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-03-2016, 06:23 PM
  3. Vcds
    By dannyh1991uk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-01-2014, 04:37 PM
  4. Vcds
    By mjom89 in forum VCDS - General Questions
    Last Post: 12-12-2013, 12:33 AM
  5. vcds help.
    By scottyb9r in forum VCDS - Help Requests
    Last Post: 01-01-2013, 01:58 PM
