Thread: BiTdi Electronic Turbo Actuator?
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
  1. BiTdi Electronic Turbo Actuator?
    Jan 2009
    Ilkley, West Yorkshire, United Kingdom
    2012 3.0 BiTdi 129K miles.
    Glow plug light started flashing today and the car went into limp mode..
    VCDS scan revealed various faluts relating to actuator/solenoid/short to power, but after clearing the codes a couple of times, these are consistent...
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 4G0 907 589 A HW: 4G0 907 589
    Component and/or Version: 3.0BTD EDC17 H21 0004
    Software Coding: 122A4012057601020800
    Work Shop Code: WSC 02391 785 00200
    ASAM Dataset: EV_ECM30BTD0114G0907589A 001005 (AU57)
    ROD: EV_ECM30BTD0114G0907589A.rod
    VCID: 326CC18A65B421D12F-8066
    3 Faults Found:
    5319 - Control Circuit for Controller for Turbocharger 1 (J724)
    P3348 00 [036] - Electrical Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 208979 km
    Date: 2020.01.24
    Time: 17:51:59
    Engine speed: 1556.50 /min
    Normed load value: 73.3 %
    Vehicle speed: 10 km/h
    Coolant temperature: 45 °C
    Intake air temperature: 14 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.200 V
    Unlearning counter according OBD: 40
    Accelerator pedal travel: 24.08 %
    Charge Pressure Actuator: activation: 96.20 %
    Charge Pressure Actuator: acknowledgment: 55.70 %
    Turbocharger boost control: offset closed: 0.00 %
    Turbocharger boost control: offset open: 0.00 %
    High press turbocharger actuator: actual uncond volt value: 2648.8 mV
    9126 - Actuator Module for Turbocharger 1
    P00AF 00 [032] - Stuck
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 208979 km
    Date: 2020.01.24
    Time: 17:14:59
    Engine speed: 809.00 /min
    Normed load value: 20.8 %
    Vehicle speed: 0 km/h
    Coolant temperature: 53 °C
    Intake air temperature: 29 °C
    Voltage terminal 30: 14.480 V
    Accelerator pedal travel: 0.00 %
    Charge Pressure Actuator: activation: 5.00 %
    Charge Pressure Actuator: acknowledgment: 100.63 %
    High press turbocharger actuator: actual uncond volt value: 4281.4 mV
    9127 - Actuator Module for Turbocharger 1
    P00AF 00 [167] - Stuck
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 208980 km
    Date: 2020.01.24
    Time: 18:21:11
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Coolant temperature: 60 °C
    Intake air temperature: 12 °C
    Voltage terminal 30: 11.760 V
    Charge Pressure Actuator: activation: 100.00 %
    Charge Pressure Actuator: acknowledgment: -4.82 %
    High press turbocharger actuator: actual uncond volt value: 254.0 mV
    Google indicates the possibility of a failed Hella electronic actuator?
    TIA.
  2. Re: BiTdi Electronic Turbo Actuator?
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Quote Originally Posted by
    P00AF 00 [167
    - Stuck
    I had this one last year, audi wanted to replace the biturbo unit at 5k, tps said there is a repair kit @£380 which I believe was the actuator, unfortunately was on back order and took 5 weeks to arrive, was fitted under warranty and car has been fine since.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: BiTdi Electronic Turbo Actuator?
    Jan 2009
    Thanks Dean.
    Quick Google suggests that replacement actuators may be available, subject to correctly identifying exactly which one I might require.
    Few checks with VCDS this morning.
    When I ran the output test for 'Exhaust Turbocharger 1' nothing visible happened and I'm assuming that this actuator should have cycled its lever?....
    When I ran the output test for 'Wastegate Bypass Regulator Valve', it cycled the vacuum controlled lever in this short video, but I'm not sure how to check whether the range of travel is sufficient?....
    EML is now illuminated, as well as the flashing glow plug light.
  4. Re: BiTdi Electronic Turbo Actuator?
    Jan 2009
    I forgot to add:
    There is also some 'noise' as the engine slows down on the overrun when revved at standstill; it sounds like it's releasing air/boost and it's coming from under the air filter/intake area.
    I heard the noise before I plugged the VCDS in and I assumed that the problem was just a leaking boost hose.
  5. Re: BiTdi Electronic Turbo Actuator?
    Jan 2009
    Left it to reset properly today, cleared the fault codes with VCDS and started it up 'gently' =
    No dash light warnings and the 'expelling air sounds' weren't evident while the engine felt normal.
    But as soon as it tried/needed to boost at all (up my steep drive), the glow plug light started flashing again and the overrun noises returned.
    Spent some time today with Google...
    I'm a reasonably competent 'mechanic' with my motorsport toys and I'm reasonably competent with VCDS as a fault finding/preference enabling tool....
    I've no previous experience whatsoever with TDIs tho.
    Should my No1 turbocharger's electronic actuator controller move at all during a VCDS 'output test'?
    Should it be easy(ish) to move manually with the ignition off?
    Was the pneumatic wastegate controller's movement (in the video) sufficient?
    If I buy a direct replacement electronic actuator, will it need to be 'paired' with the turbo?
    If I buy a complete new replacement BiTdi unit, will it be plug and play?
    If I buy a complete refurb replacement BiTdi unit, will it be plug and play?
    TIA.
  6. BiTdi Electronic Turbo Actuator?
    Dec 2007
    44 Post(s)
    I believe the actuator will have to be calibrated, a used bitdi unit I expected would go straight on, a refurbished turbo, i would think its pot luck. All depends if they have the equipment to calibrate the actuator.
  7. Re: BiTdi Electronic Turbo Actuator?
    Jan 2009
    Came across your post on Pistonheads Dean, how did yours turn out in the end (waited 5 weeks for repair kit)?
    Was yours a Hella actuator?
    From what I've read, the repair kit covers the mechanical aspects only and there are no visible signs of mechanical damage with mine.
    We disconnected the arm on the actuator today and the arm moved very freely, indicating that the variable vanes aren't sticking, so my pal dived in and removed the electronic actuator, which is a Hella.
    I've read that the Hella actuators don't need to be calibrated???
    Google reports that the worm drive gears are prone to failing and I'd hoped that there would be some visible signs of failure, alas not......
    Not sure what to do next, so I've taken a punt on ordering a new Hella actuator and crossed my fingers.
  8. Re: BiTdi Electronic Turbo Actuator?
    Jan 2009
    FIXED!
    No £6K at the Audi dealer or DIY £3.5K+ for a new turbo unit.
    £182 all-in, for an allegedly "100% new old stock actuator".
    For reference:
    The actuator that came off was visibly fine and it even wound itself back to its default/fail position after being manually forced to open.
    There were no broken gears inside the actuator and the electric motor was working.
    Presumably the actuator had developed an 'electronic' fault on its board.
    The replacement Hella actuator was plug 'n' play (no calibration required) and the car drives perfectly again with no fault codes registering.
    Quote Originally Posted by M3 Compact View Post
    YES!.....
    No.
    My 'wastegate'/variable vane ring lever moved extremely freely without any resistance or dragging whatsoever when the actuator was disconnected; the actuators aren't meant to be moved manually.
    Happy days.
    0 2 0
  9. Re: BiTdi Electronic Turbo Actuator?
    Dec 2007
    44 Post(s)
    So you just fitted the part and no calibration required?
  10. Re: BiTdi Electronic Turbo Actuator?
    Jan 2009
    Quote Originally Posted by dean warren View Post
    Yes Dean.
    I researched it extensively on line and the reports stated that the Hella actuators don't need calibrating.
    I was lucky and mine had a Hella, apparently there are 2 different types of actuator fitted to these cars and the non-Hella actuators allegedly need to be calibrated with the turbos removed. (No idea why.)
  1. 3.0 Tdi Turbo Electronic Actuator adaption tool VAS 6395 need help in Bradford Yorkshire
    By Roommy in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 28-01-2019, 03:58 PM
  2. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  3. Question BiTDI Turbo Lag
    By hshah in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-08-2015, 07:56 PM
  4. turbo actuator
    By meganall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-08-2012, 01:28 PM
  5. turbo actuator
    By mygolfygti in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2009, 11:43 PM
