Thread: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 114
  1. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #21
    Sep 2020
    England
    Did you have to remove the front end of the car off to get the DPF out
  2. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #22
    Dec 2008
    19 Post(s)
    No not completely just remove the bumper and loosen the bolts in preparation for front end removal and wiring plugs . Slide front end forward a few inches and the dpf will come out from the top.
  3. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #23
    Nov 2020
    Maidstone
    Quote Originally Posted by liam walsh View Post
    When you say undo the bulkhead what do you mean exactly? Did you take the driveshaft off?
  4. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #24
    Dec 2008
    19 Post(s)
    You can remove the steel bulkhead panel just behind the engine it gives you all the space you need to work on the back of the engine . No I didnt take driveshafts off there is no need everything can be done from above except a few dpf bolts if you are taking out the dpf.
  5. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #25
    Nov 2020
    Maidstone
    Cool ok cheers, I've started taking mine off today but currently stuck on the bolts that join the dpf to the exhaust there just isn't any room to get anything on them
  6. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #26
    Dec 2008
    19 Post(s)
    When you take off the bulkhead panel you can get through to the 3 bolts holding the dpf to the exhaust using a few long extensions. You can see all three bolts heads if you remove the airbox. The bolts are torx spline heads . To remove the bulkhead panel you have to disconnect the heater pipes as they go through the panel.
    You do know on that engine the egr cooler is attached to the dpf also. You have to take out the egr cooler to get out the dpf.
  7. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #27
    Nov 2020
    Maidstone
    Thanks mate lol, did you re-use the gaskets?
    Yes I know they are joined together pretty much.
  8. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #28
    Dec 2008
    19 Post(s)
    I think the only gasket is the one for the egr cooler to the dpf/scr cat. I didnt reuse because I ended up fitting a new egr cooler in the end but I would have reused it if I was putting the old one back in.
    What's wrong with your car?
  9. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #29
    Nov 2020
    Maidstone
    Money light keeps coming on with code p2002, it hasn't gone in to limp mode yet but just annoying being on all the time so thought I would do it while I'm furloughed. It had only done 40k miles when it first come on
  10. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #30
    Dec 2008
    19 Post(s)
    Save yourself a load of hassle and change the map sensor first. 10 minute job . About £80 from audi.
  1. Question Heater Matrix Removal and cleaning
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2017, 07:57 PM
  2. Replies: 19
    Last Post: 19-07-2016, 11:51 AM
  3. Question EGR Removal for cleaning/replacement
    By Ant7t5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 08:26 PM
  4. Oil cooler removal
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2009, 03:37 PM
  5. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 09:46 PM
