Thread: Golf MK6 Longitudinal acceleration sensor code 01279
  1. Golf MK6 Longitudinal acceleration sensor code 01279
    Jan 2020
    Rickmansworth, England
    Hi all,
    After replacing my car battery a while ago, the esp light has failed to go off. I've tried the trick of turning my wheel from right to left and driving straight with no luck. Plugged in the carista app and came up with the error codes:
    01279 Longitudinal acceleration sensor G251
    02085 Incorrect control module installed (ABS)
    01314 Engine control module (ECM)
    I believe on some older models this could be located behind the glovebox which would be easy but it isn't located there. Am I right in believing in the MK6 that it's built into the ABS control module and that this needs to be replaced and coded which is a lot more expensive as I don't have any vcds software?
  2. Re: Golf MK6 Longitudinal acceleration sensor code 01279
    Aug 2020
    wales
    Did you find out where this longitudinal acceleration sensor g251 sensor is on a mk6 golf?
  3. Re: Golf MK6 Longitudinal acceleration sensor code 01279
    Aug 2022
    Highland
    I have the same codes excepting 01314. Did you find what the cause was?
  4. Re: Golf MK6 Longitudinal acceleration sensor code 01279
    129 Post(s)
    1972 Post(s)
    @Andy655 It would be better to start your own new thread, include a full scan and the cars VIN.
  5. Re: Golf MK6 Longitudinal acceleration sensor code 01279
    May 2023
    Gothenburg
    I have the same problem. Just can´t seem to find the Longitudinal acceleration sensor position. Did you ever solve the issue?
  6. Re: Golf MK6 Longitudinal acceleration sensor code 01279
    129 Post(s)
    1972 Post(s)
    As in post 4
  1. Replies: 5
    Last Post: 28-03-2012, 10:27 AM
  2. golf4 v6 4motion error code 01279
    By hoggy in forum VCDS - Help Requests
    Last Post: 17-08-2009, 09:58 AM
  3. golf4 v6 4motion error code 01279??
    By hoggy in forum Golf MK4 - 1999 - 2004
    Last Post: 16-08-2009, 10:58 AM
  4. S3 Longitudinal Accel Sensor
    By AK30 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-02-2008, 09:20 PM
  5. TT longitudinal sensor calibration
    By Academy in forum Archive posts
    Last Post: 24-09-2007, 04:38 PM
