Thread: VW Passat 1.6tdi 2012 Flashing glow plug light
  1. VW Passat 1.6tdi 2012 Flashing glow plug light
    Jan 2020
    basingstoke, Uk
    I have a flashing glow plug light come on for last few weeks and car goes in limp mode when it is on. It goes off when I restart the car and comes back on after some times. Some times it doesnt appear for days and sometimes it comes on after few minutes. I have noticed it mainly comes on during cold and wet weather. The car is usually shaking in the morning and I have seen the water levels go down more quicker than usual. I have run a diagnostic and the code is P046C which apparently is EGR related issue.
    Any advise on what this could be and what would be the best way of fixing it? I have been told that cleaning the EGR an fix it? And have been quoted £50 for EGR clean if its at front of engine and significantly more if its at the back. Do I need to clean the unit or just get it cleaned and what are rough costs of replacing it?
  2. Re: VW Passat 1.6tdi 2012 Flashing glow plug light
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Fault code: P046C Exhaust Gas Recirculation Sensor "A" Circuit Range/Performance.
    You report that the engine is using coolant as well.
    This could be the EGR cooler leaking into the EGR & being ingested by the engine ( & this also could be the reason for the shaking at start-up ) , but of course could be something else.
    Cleaning the EGR is a waste of time as it takes a lot of time & effort to remove.
    If you havn't had the emissions update, book it in & present the car without the glow light flashing & you may well be able to get a free EGR with the VW "Trust Building Measure"
  1. Question 2007 Passat 2.0 TDI Glow Plug light flashing
    By jmurray01 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-11-2018, 10:54 PM
  2. Please Help Passat B6 EML and flashing glow plug light
    By MarkC89 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2017, 10:22 AM
  3. passat 58 flashing glow plug light
    By Danny Wood in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-02-2016, 12:09 PM
  4. Please Help passat b6 DPF FAULT LIGHT AND glow plug FLASHING.
    By usa in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2015, 02:39 AM
  5. B6 passat tdi glow plug light flashing
    By ctm73 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-06-2014, 09:36 PM
