Thread: ESP/ABS/TPMS fault after carrying heavy load
Results 1 to 10 of 12
  1. ESP/ABS/TPMS fault after carrying heavy load
    Aug 2019
    Harrogate
    Hi all,
    Today I carried 10 flag stones in my A6 Avant for around 1.5 miles from the local builders yard. Around half a mile in and I got an ESP ABS fault along with TPMS error and parking brake error.
    It’s still an issue several hours later even without the load in now.
    I have the Carista OBD scanner and these are the codes;
    Engine:
    04698
    04699
    ABS:
    00486 - Tracers for Central Locking, door external grasp front seat passenger side (E370)
    00365 - Line for communication interior monitoring, entrance
    00393 - Display test, black segments
    00398 - Finding lighting
    00402 - Heating element for air additional heating system (Z35)
    Airbags:
    1049350
    Steering wheel:
    01316 - ABS Control Module
    Parking brake:
    459776
    Power steering:
    3164944
    Carista is very basic and obviously a VCDS reading is needed but initially the 01316 - ABS control module seems the worst culprit here.
    Elsewhere I’ve read it could just be a abs speed sensor error, and most likely on my rear right after carrying the weight.
    Can anyone offer me any help?
    (I’m in Harrogate, if anyone happens to be on here from the area with a scanner!!)
    Ben
  2. Re: ESP/ABS/TPMS fault after carrying heavy load
    May 2018
    Kent
    7 Post(s)
    Check your tyre pressures are spot on and reset them , clear the faults and see what happens. Likely the extra weight without increasing the tyre pressures has upset the system ( for want of a better way of putting it)
  3. Re: ESP/ABS/TPMS fault after carrying heavy load
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    What he says.
  4. Re: ESP/ABS/TPMS fault after carrying heavy load
    Aug 2019
    Harrogate
    Thanks for your time! Unfortunately that hasn’t worked. Still getting all the lights.
    The start stop system is giving an error message in addition to the others too.
    Someone suggested disconnecting the battery to try reset it. Could that work?
  5. Re: ESP/ABS/TPMS fault after carrying heavy load
    Aug 2019
    Harrogate
    Is anyone able to PM vcds-harrogate for me please? I've not got enough forum posts to, and hoping he might be able to help with a scan.
  6. Re: ESP/ABS/TPMS fault after carrying heavy load
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by Benish7 View Post
    Are you sure? They haven't posted since 2014, or visited since 2016?
  7. Re: ESP/ABS/TPMS fault after carrying heavy load
    Aug 2019
    Harrogate
    Quote Originally Posted by VAG-Abound View Post
    Ah fair enough, I hadn't noticed that.
  8. Re: ESP/ABS/TPMS fault after carrying heavy load
    Aug 2013
    East Yorkshire
    7 Post(s)
    TPMS, ESP, ABS, stop/start and parking brake warning lights are all linked to a failure of a speed sensor at a hub. The failure may be the electronic speed reader or the sensor disc which is part of the wheel bearing.
    You could have tried to carry too much weight and now have knackered the bearing.
    John.
  9. Re: ESP/ABS/TPMS fault after carrying heavy load
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Depending on material, area and thickness a slab coukd be anything from about 30kg to 90kg. Were they like a really heavy suitcase (30kg) or two-man heavy lift?
    Even ten 30kg ones woild be best distributed on footwells, etc to mimic carrying a trio of rugby players.
    Do you think it might have been overloaded?
  10. Re: ESP/ABS/TPMS fault after carrying heavy load
    Aug 2019
    Harrogate
    They probably weighed half a bag of sand each. I didn’t think, at the time, it was a problem!
    This morning when I went to the car the faults had gone, car must have reset itself. Unfortunately on the way home though they came back on. Seemed to happen after I came down off a curb after parking up.
    Latest Carista fault codes:
    Engine:
    04698
    04699
    ABS:
    00362 - Actuator for amount of air flap at the rear-left (V239)
    00368 - Absorbers in front left hard
    Airbags:
    1049350
    1049605
    Steering wheel:
    Parking brake:
    459776
    Power steering:
    3164944
    Any ideas on 00362 and 00368?
  1. Smoke under heavy load - any thoughts on cause please?
    By Rustychain in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-02-2019, 08:44 PM
  2. TPMS fault
    By juice in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 01-04-2017, 06:10 PM
  3. 2002 A4 Avant Quattro - load carrying capacity.
    By Brahan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-06-2016, 01:54 PM
  4. Avant and heavy load
    By fernar in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-01-2013, 12:08 PM
  5. Allroad 2.5 tdi - squealing noise under heavy load
    By craig_ in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2012, 08:44 AM
abs, esp
