Thread: Audi A6 C6 windscreen wipers died.
  1. Audi A6 C6 windscreen wipers died.
    Jun 2012
    Surrey
    6 Post(s)
    The wipers on my A6 just died, stopped on the screen. It seems I can hear the motor whirring so it is a mechanical failure.
    I can easily move the wipers up and down so its not seized.
    Does anybody know is there something common fails that can be repaired or will it be a whole replacement part....is the motor known to strip the fitting to the linkage?
    How is the assembly accessed.....and .is there any guidance as to what needs moving to get the parts out.
    Thanks for any help...its off the road for sure in this weather!!
  2. Re: Audi A6 C6 windscreen wipers died.
    Jun 2012
    Surrey
    6 Post(s)
    I have found the issue.....a nylon ball joint just under the motor is separated on the linkage. I have popped it on but it is clapped so will fall off again!
    Anyone found a repair without replacement?
  3. Re: Audi A6 C6 windscreen wipers died.
    Jul 2013
    76 Post(s)
    You can get the bushes from here http://wiperrepairs.com/
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: Audi A6 C6 windscreen wipers died.
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    They are known to seize up, may need removing and cleaning/freeing the linkage.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  5. Re: Audi A6 C6 windscreen wipers died.
    Jun 2012
    Surrey
    6 Post(s)
    perfect thanks, the first nylon joint under the motor is clapped...falls off. The proper joint repairs is the way to go on all 4, far better than those quick fix metal hold up plates which will not take play out the joints.
  1. Rear Windscreen Wiper, went rogue then died.
    By Alfonzo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2012, 11:16 AM
  2. Audi 80 tdi 1994 - windscreen wipers
    By zed01 in forum 80 - 90
    Last Post: 13-07-2011, 09:21 PM
  3. Windscreen wipers
    By Chrisman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-12-2010, 08:22 PM
  4. Windscreen Wipers
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-03-2010, 08:29 AM
  5. Please Help windscreen wipers!!
    By Raymarshall43 in forum Chat - Anything with wheels
    Last Post: 01-09-2008, 03:10 PM
