Thread: How to disable your stop/start the easy way
Results 1 to 10 of 13
  1. How to disable your stop/start the easy way
    May 2008
    40 Post(s)
    This is on a 2013 Allroad with 3.0tdi so maybe different for other vag motors?
    Look at the battery, see the negative terminal? and it has a very small connector fitted, unplug said connector and thats it job done.
    I of course am not advocating doing this full time Greta might get upest but as a get you home trick or you want to fit a standard (non stop/start) and therefore much cheaper 019 battery this is the way to acheive it.
  2. Re: How to disable your stop/start the easy way
    May 2008
    40 Post(s)
    Just been told on facebook (where else!) that the little plug is how the car monitors the battery condition, so proceed at your own risk.
    I will leave ours as is and report back after a few weeks.
  3. Re: How to disable your stop/start the easy way
    Mar 2013
    Reading
    31 Post(s)
    ... or just find someone with VCDS/OBD11 and change a single setting to "remember" the last state of the dash button. Job done & you're not harming anything else!
    Sent from my mobile...
  4. Re: How to disable your stop/start the easy way
    May 2008
    40 Post(s)
    Still running just fine, another bloke confirmed his has been like this for two years with zero issues.
  5. Re: How to disable your stop/start the easy way
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Dissabled completely with VCDS. No lamp on .No need to worry about it.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: How to disable your stop/start the easy way
    Jul 2006
    Bloxham, Oxon
    Quote Originally Posted by Alan02 View Post
    Please can you point me in the right direction - how to do this with VCDS ?
  7. Re: How to disable your stop/start the easy way
    Feb 2013
    Finland
    13 Post(s)
    First sticky #25 :
    25. Disable/memorize/invert Start & Stop
    [Select]
    [09-Cent. Elect.]
    [Security Access - 16] (enter security code - 20113)
    [Adaptation - 10]
    Select Channel 34 and Read
    if you subtract 4 from the original value --> Start&Stop always disabled
    if you add 32 to the original value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
    if you add 64 to the original value --> Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
    Press Test then press Save
  8. Re: How to disable your stop/start the easy way
    Jul 2006
    Bloxham, Oxon
    Brilliant thanks
  9. Re: How to disable your stop/start the easy way
    Jul 2006
    Bloxham, Oxon
    Well, tried that but the security code 20113 was "refused by controller".
    The car is a 2011 A3 2.0TDi 170 quattro.
    My version of VCDS is a 2012 so quite old, but has previously worked well on this car.
    Any ideas ?
  10. Re: How to disable your stop/start the easy way
    Feb 2013
    Finland
    13 Post(s)
    No idea, except why not update vCDS?
  1. Disable start / stop via VCDS
    By MC09PJC in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-12-2018, 01:50 PM
  2. Disable Start/Stop
    By St3veM in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 08-08-2018, 11:45 PM
  3. Stop start disable
    By mauricedar in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-08-2017, 04:55 PM
  4. Audi A3 8P start / stop system reverse or disable ?
    By Xanthos in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-01-2016, 06:43 PM
  5. Disable Stop/Start
    By a8tdi in forum A8 - S8 - V8
    Last Post: 30-08-2013, 05:58 PM
