Thread: Newbie A6 rear bulbs question
Results 1 to 10 of 14
  1. Newbie A6 rear bulbs question
    Oct 2019
    Farnham England
    Hello everyone . My first post with a question . I have an Audi A6 2009 2.0 Tdi Se. I have warning lights on the dash regarding the rear lights left turn indicator , brake light, running light . There is a crack in the rear (wing mounted) lens which appears to have let some moisture into the unit . These faults regarding the indicator brake bulb in the main lamp housing in the wing are intermittent. Do I need to replace the lens unit I have read that this looks like a common problem. Also It looks like I have a nearside issue in the Boot lid mounted lamps . I can't see anyway of removing the boot lid internal trim to access the back of the lens units . Do I need a special pry tool to get the trim off, any ideas?. I have seen hinged flaps on some A6 cars for this purpose but not on mine. I appreciate any help out there . thanks ..
  2. Re: Newbie A6 rear bulbs question
    Aberdeen
    63 Post(s)
    Welcome. I have moved your thread to the correct section - welcome section is to introduce yourself. Hopefully you will get some answers. Try searching boot trim removal as this has been asked a few times.
    Faults can also come on intermittently if the incorrect bulb has been fitted or if the bulb is on its way out. These models are well known for leaking rear light clusters!
    Good luck
  3. Re: Newbie A6 rear bulbs question
    Mar 2009
    Montenegro
    13 Post(s)
    Your car is 2009 and it is facelift model. It means that you have led lamps and some are normal bulb. Facelift models do not have problems with cracks (that was only on 2004/2005 models). As you have errors of few lights it indicates power issue. Check if power is arriving and all contacts are clean from rust/oxidation.
    Sent from my Redmi Note 7 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  4. Re: Newbie A6 rear bulbs question
    Oct 2019
    Farnham England
    many thanks for your input Ill check it out .
  5. Re: Newbie A6 rear bulbs question
    Oct 2019
    Farnham England
    Apologies only ever had work done by Audi . so probably a potential bulb fail or contuinuity issue . Thanks for your help.
  6. Re: Newbie A6 rear bulbs question
    131 Post(s)
    1973 Post(s)
    Remove the rear lamp unit and check the plug and socket for heat damage to the earth pin, this is a very common issue on the A6 and TT2 when the unit has incandescent bulbs and appears to predominantly affect automatic models and if you think about it, it is obvious why this happens but not why just on the left?
  7. Re: Newbie A6 rear bulbs question
    Jul 2008
    Lisburn
    16 Post(s)
    itll be hard to measure - i tried this on mine but once the fault by the car the power is cut - is what i found out anyway.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  8. Re: Newbie A6 rear bulbs question
    Oct 2019
    Farnham England
    Hello , there is a 13 mmm retaining nut which I removed thinking that the lens assembly could be coaxed forward so I can get to the connector . Other than brute force is there anything (like another lock nut that I'm missing) Just worried if I try too hard Ill break something
  9. Re: Newbie A6 rear bulbs question
    Jul 2008
    Lisburn
    16 Post(s)
    it also pops into a ball joint type socket, take a look on 7zap this will give you an idea of where and how to apply force.
    Stewart
  10. Re: Newbie A6 rear bulbs question
    Oct 2019
    Farnham England
    Garage reckons I need a complete new bulb holder quoting £240 fitted . I checked the 7zap website but I can't find the detail to which you are referring . I would like to take a look myself before I embark on spending serious money on what might be an easy fix . Could you post a link on where I can find the detail of the ball and socket joint. I would appreciate it . Cheers
  1. Newbie: A4 2011 - LED Number Plate Bulbs?
    By Ryan Duffy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-10-2014, 04:57 PM
  2. Newbie question: how to replace rear wiper?
    By psynnott in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-11-2011, 09:51 AM
  3. Please Help Lazy Question - Brake Bulbs
    By Bobster-cyw in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2011, 08:49 PM
  4. Question Bulbs question, please..
    By Roguebrit in forum Golf MK5 - 2004 - 2009
    Last Post: 09-07-2008, 11:05 AM
  5. Newbie needing help with Audi A4 Interior bulbs !!
    By readbmr in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2007, 02:04 AM
