Thread: MOT Advisory
Results 1 to 10 of 10
  1. MOT Advisory
    Dec 2013
    Liverpool
    10 Post(s)
    Can someone help me with part numbers for my A6 Quatro? the advisory says "Suspension arm pin or bush worn but not resulting in excessive movement Nearside (and also Offside) front lower".
    Can the bushes be replaced or would it be new parts? does anyone have a schematic with parts identified????? Need help identifying parts please. 2007 saloon
    2007 2.7 SE quattro saloon
  2. Re: MOT Advisory
    134 Post(s)
    2009 Post(s)
    You can buy the bushes original, aftermarket or performance oriented but is it the pin or the ball joint? The faulty arms need to be identified and the fault defined but most people just fit new arms and the choice of manufacturers is HUGE, from Chinese ultra budget to h/d better than original or indeed original so if it is what I think, the so called “control arm” 4F0 407 151 A AKA front lower forward link or strut link, then you can pay from £224.27 genuine and warranted for 2 years parts and labour or as little as £35 for something with a first lamppost warranty...
  3. Re: MOT Advisory
    Dec 2013
    Liverpool
    10 Post(s)
    Many thanks Crasher.
  4. Re: MOT Advisory
    Dec 2013
    Liverpool
    10 Post(s)
    Found Lemforder parts at £80.00 each plus fixings, also found Vaico at £42.00 ea. Are Vaico a quality part to use?? Can't understand a £38.00 per unit difference.
  5. Re: MOT Advisory
    Dec 2013
    Liverpool
    10 Post(s)
    Moog & Metzger both at £65.00 per unit.
  6. Re: MOT Advisory
    May 2014
    Darlington
    78 Post(s)
    Fit Lemforder if you want the part to last. It's most likely a lemforder part on the car and it's lasted 12 years.
  7. Re: MOT Advisory
    134 Post(s)
    2009 Post(s)
    The original parts are usually TRW but Lemforder are very good.
  8. Re: MOT Advisory
    Mar 2009
    Montenegro
    13 Post(s)
    I have recently changed stabilizer links on my A6.
    During changing of the links I saw some bushes start showing age.
    So, I decide to take numbers from this site:
    My parts numbers are
    Bushings:
    4E0 407 181B lower arm connection to shock absorberl
    4E0 407 182C lower arm connection to subframe
    4F0 407 183E lower arm back
    8D0 407 515C upper arms
    4F0 411 327J rubber for stabilizer
    Nuts and bolts
    N 91016602 bolt for lower arm front
    N 10106402 nut for lower arms
    N 90965602 nut for lower arms on balls
    N 90625902 bolt for lower arm back
    N 10425302 bolt for upper arms
    N 10286110 nut for upper arms
    N 10516702 bolt for stabilizer lower
    N 10425302 bolt for stabilizer upper
    N 10286110 nut for upper stabilizer link
    N 10491802 bolt that hold upper links' balls
    N 10272302 nut for bolt that hold upper links' balls
    N 91001202 bolt for upper cover of shock absorber.
    Sent from my Redmi Note 7 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  9. Re: MOT Advisory
    Mar 2009
    Montenegro
    13 Post(s)
    By the way, on the net I found the prices for all bushes and set of bolts and nuts in amount of 150 euro cheaper then to buy complete arms ( links)
  10. Re: MOT Advisory
    Dec 2013
    Liverpool
    10 Post(s)
    Quote Originally Posted by peter goble View Post
    Sorry for re-visiting this post, finally got round to getting the parts fitted, my friend took it into a garage where we could get it up on a ramp for ease of access only to find the MOT inspector had actually marked the near side and off side rear lower, not happy after paying £170 for the fronts as advised on the MOT. can anyone advise the part numbers for these parts now??
  1. MOT Advisory Help
    By Alex Himself in forum Bora - 1998 - 2005
    Last Post: 11-03-2015, 10:48 PM
  2. Advisory on MOT
    By phildamb in forum Bora - 1998 - 2005
    Last Post: 18-06-2014, 03:42 PM
  3. Subframe MOT Advisory
    By Dsldude in forum Polo - Derby - Lupo - Fox
    Last Post: 13-04-2011, 02:13 PM
  4. Question MOT Advisory?
    By mike777 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-08-2009, 08:44 PM
  5. Question MOT Advisory item
    By rodaire in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-05-2008, 09:49 PM
