Thread: Can ECU plug sockets replaced?
  1. Can ECU plug sockets replaced?
    Aug 2019
    ECU plugs have water ingress and have corroded. One pin has also snapped off. Is it possible to replace just the black plastic socket housing, or is a new ECU needed? Quote for a new one is £1600, and apparently to fit one via a scrapyard is expensive and time consuming. Has anyone had a similar issue and can offer some advice?
  2. Re: Can ECU plug sockets replaced?
    Birmingham
    7 Post(s)
    You can repair the sockets by changing the individual pins. There are repair wires available from the dealer that have a piece of wire on it so you simply cut off the old one and solder the new one on.
    Alternatively is get a complete socket from a car at the scrap yard.
    If you are not comfortable doing this, find an auto electrician and they will be able to do this repair.
  3. Re: Can ECU plug sockets replaced?
    Aug 2019
    Quote Originally Posted by mike ryan View Post
    Thanks for your reply. I am happy to attempt the fix myself, but what I’m not sure about is, is it possible to just open the ECU and easily access the back of (or remove) the plug socket unit from the ECU. I have found a set of screws online that are designed to prise open the casing without damaging it, but they’re £20. Didn’t want to spend the money just to find out the parts inside were unserviceable or inaccessible.
  1. Rear (2nd row) 12V sockets
    By Nemo78 in forum Q7 - 4M Forum - 2016 -
    Last Post: 24-08-2017, 01:20 PM
  2. Audi A5 3.0TDi MY11 glow plug light g450 replaced 3 times ! help please
    By A5 PETE in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 24-07-2016, 07:14 AM
  3. Acc Sockets
    By DSG4ME in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2010, 10:22 PM
  4. Question 12V sockets
    By sidemoor in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-09-2008, 06:32 PM
  5. help please - cig sockets not working
    By jay69 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2008, 10:27 AM
