Thread: Dpf regen soot
Results 1 to 10 of 12
  1. Dpf regen soot
    Mar 2012
    england
    What’s the difference between soot measured and calculated
    I have been having my car doing regen it went away and stopped reving a little while ago then come back I drove at 40/50mph air con on 2500 rpm for 15/20 mins a couple of trips before when I scanned it was at 18.00g now it’s down to 8.01g on the calculated and -2.26 on the measured
    What is the good soot levels is it as low as possible
    Cheers Matt
  2. Re: Dpf regen soot
    130 Post(s)
    1972 Post(s)
    18 is about normal for coming upto regen, 8 is fine. Doing a forced regen I like to see it go down to zero but when you come back to it later it has usually gone back upto around 4%.
  3. Re: Dpf regen soot
    Mar 2012
    england
    Ok cheers I done a forced and it didn’t drop at all as it was doing it for 40 mins Seems I have managed to get it lower with the driving regen 3/4 gear In manual 2500 rpm around 40/50mph for 15 mins etc
    Haven’t yet tried a vcds driving regen though
    I have noticed these multitronic gearboxes it’s never going to regen itself as the revs are always so so low
    Cheers Matt
  4. Re: Dpf regen soot
    130 Post(s)
    1972 Post(s)
    Fit a new GENUINE DPF pressure sensor, calibrate it, clear the learnt adaptations (NOT THE ASH MASS!) and do a forced regen, sometimes there is a good on screen function (sometimes the glory of a standing regen where you can go have a coffee) but quite often in VCDS it is a bit of a hit and miss guessing game such as changing the stored value to 00 01 and seeing if the DPF light comes on.
  5. Re: Dpf regen soot
    Mar 2012
    england
    I will contact Audi get a price on the pressure sensor it looks pretty easy to change . Think it’s the calibrating it will be difficult ?
    Yesterday I plugged the laptop in went to regen while driving change 0 to 1 and it come up with yes no cancel
    I clicked yes and said about changing numbers to 1234 etc
    Dpf warning light come on I then drove temp got up soot was coming down but traffic slowed to much need to do it On a quiet time .
    I tuned car off back on Dpf was back off again
    Cheers Matt
  6. Re: Dpf regen soot
    Mar 2012
    england
    Tonight I was having a drive and was in sport mode and giving it some beans and when I got to a slow area went back to drive and the car was doing the reving at 1400rpm when coming to a stop . This is what I think is the regen process
    Would this be the sensor causing it as it’s on soot measured is -2.26 g
    Cheers Matt
  7. Re: Dpf regen soot
    130 Post(s)
    1972 Post(s)
    There is actual and measured.
  8. Re: Dpf regen soot
    Mar 2012
    england
    Mine is calculated 8.10g
    And measured is -2.26
  9. Re: Dpf regen soot
    Mar 2012
    england
    From what I have been told on vcds it’s measured that’s the differential pressure sensor messurement and calculated what the ecu thinks is in the Dpf
    I’m thinking bring -2.26 the sensor isn’t working
  10. Re: Dpf regen soot
    130 Post(s)
    1972 Post(s)
    Sorry, calculated, too hot....
  1. D P F soot levels
    By 113brucey in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2015, 07:40 PM
  2. Difference between soot measured and soot calculated?
    By gregpot2000 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-09-2014, 09:47 PM
  3. Question Soot after DPF removal.
    By mark wade in forum Golf MK5 - 2004 - 2009
    Last Post: 25-06-2013, 11:38 AM
  4. Please Help black soot
    By phase4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2010, 09:40 PM
  5. What Diesel do you use in your soot chucker?
    By Fizzbitt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-07-2007, 08:38 AM
