Thread: How to find PIN/SKC for Mk5 Golf
  1. How to find PIN/SKC for Mk5 Golf
    Oct 2017
    London
    12 Post(s)
    Hi Ive got a 2009 Mk5 Golf 1.9 BLS Bluemotion in which wont let me login. I get this error while trying to access adaptions under engine.....
    "Prior to adapting a new USED Engine Control Unit the vehicle specific PIN/SKC (IMMO-Login) of the new USED engine control unit has to be used to enable the adaptation. Youll find the PIN/SKC on the key tag of the additional key (of the donor car) and you can aquire it through your responsible distribution centre or importer"
    The guy has just bought the car and doesnt know of any new ECU, there is no second key and doesnt want to pay the dealership unless its a last resort. Is there any way to access the code?
    Many thanks
  2. Re: How to find PIN/SKC for Mk5 Golf
    Oct 2017
    London
    12 Post(s)
    Sunday,21,July,2019,22:08:28:42137
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20190529 DS308.0
    Ross-Tech: Home
    VIN: WVWZZZ1KZ9W833904 License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ9W833904 Mileage: 145590km-90465miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-021-BLS.clb
    Part No SW: 03G 906 021 TT HW: 03G 906 021 AB
    Component: R4 1,9L EDC 000SG 2745
    Revision: --H08--- Serial number: VWX7Z0H83NM98K
    Coding: 0000071
    Shop #: WSC 00835 210 105448
    VCID: 04507C0CF21156B7EE1-8050
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 233B400D092500FDC41402E4901D00813000
    Shop #: WSC 01316 785 00200
    VCID: 74B02CCCAEB16637DE1-8020
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
    Component: Climatic PQ35 142 1111
    Revision: 00142031 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 76B416C4B4CD7427E05-8022
    2 Faults Found:
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground - Intermittent
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
    Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 01000004902020
    Coding: E4890F2700041800470A00000F000000000859035C00010000 0000000000
    Shop #: WSC 01367 785 00200
    VCID: 323CEAD4182528070CD-8066
    Subsystem 1 - Part No: 5M0 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 260808 021 0501
    Coding: 00038805
    Shop #: WSC 01367
    Subsystem 2 - Part No: 1K0 955 559 AG Labels: 1K0-955-559-AG.CLB
    Component: RLS 170908 055 0402
    Coding: 04403387
    Shop #: WSC 01367
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 1K AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD273VFL
    Coding: 0012619
    Shop #: WSC 01357 011 00200
    VCID: 3D26C9E8D17BE77FE1F-8068
    Subsystem 1 - Serial number: 6332MSME3F76051EM
    Subsystem 2 - Serial number: 6342MSME400128771
    Subsystem 3 - Serial number: 6351HSME174B48428
    Subsystem 4 - Serial number: 6361HSME175D4A50D
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 CA HW: 1K0 953 549 CA
    Component: J0527 051 0101
    Coding: 0000012
    Shop #: WSC 01392 785 00200
    VCID: 73B22FD0A7BF610FC7B-8026
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 974 M HW: 1K0 920 974 M
    Component: KOMBIINSTRUMENT VDD 2420
    Revision: V0002000 Serial number: VWX7Z0H83NM98K
    Coding: 0003403
    VCID: 3828D8FCFE59C257329-806C
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533 Gateway H07 5063
    Revision: H07 01 Serial number: 140808F2002575
    Coding: E9807F060002029003
    VCID: 3536D1C8E94B3F3F29F-8060
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 2420
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1K0 959 701 AF HW: 1K0 959 701 AF
    Component: Tuer-SG 008 2030
    Coding: 0000692
    VCID: 72BC2AD4D8A56807CCD-8026
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 69 2301
    Revision: 00H15000
    VCID: 2A0CF2B430F560C7B4D-807E
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 809002005103087F2D04840560085F0380FC00
    VCID: 03527F10F71F518FD7B-8056
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1K0 959 702 AF HW: 1K0 959 702 AF
    Coding: 0000692
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 156 A HW: 5M0 035 156 A
    Component: Radio 018 0043
    Revision: R0018000 Serial number: VWZAZ1H6921293
    Coding: 0000020002
    Shop #: WSC 00835 210 91894
    VCID: 270A0B802FE75DAFAB3-8072
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
    Component: Tuer-SG 007 2003
    Coding: 0000144
    Shop #: WSC 01392 785 1012552
    VCID: 7AAC02F480D5104784D-802E
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 E HW: 5K0 959 704 E
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 01392 785 1012551
    VCID: 372ADBC0F347CD2F3B3-8062
    End----------(Elapsed Time: 01:02, VBatt start/end: 12.4V/12.2V)-----------
  3. Re: How to find PIN/SKC for Mk5 Golf
    Oct 2017
    London
    12 Post(s)
    Two cars in a week with exactly the same problem, very strange. The owner knows a bit more about this one and its had the clocks changed.....
  4. Re: How to find PIN/SKC for Mk5 Golf
    129 Post(s)
    1972 Post(s)
    You can no longer obtain the SKC or indeed even use it, the PIN is accessible with systems such as CAN Commander but cloned dodgy versions are very unreliable. The reliable way is with ODIS so a main dealer or so equipped specialist. When doing this job in ODIS you now see absolutely nothing, it is all done remotely.
  5. Re: How to find PIN/SKC for Mk5 Golf
    Oct 2017
    London
    12 Post(s)
    Had a Leon in today with exactly the same issue. 3 cars in one week, no way! It cant be a coincidence its only happened since I updated to 19.6.1 on VCDS. Its something they have done on the update thats now asking for this pin before I can do anything in adaptions. Will drop them an email and try and go back to the old version in the meantime just to confirm.
  6. Re: How to find PIN/SKC for Mk5 Golf
    129 Post(s)
    1972 Post(s)
    I am a bit confused, what are you trying to do? Adaptation of a new key?
  1. how do i find out what ecu is in my golf
    By darrendee09 in forum Golf MK5 - 2004 - 2009
    Last Post: 28-10-2012, 01:07 AM
  2. Trying to find a new golf.
    By Oddball in forum Golf MK2 - 1984 - 1992
    Last Post: 16-02-2009, 10:40 PM
  3. Where to find VW GOLF MK4 starter relay
    By Dj_Ghost in forum Golf MK4 - 1999 - 2004
    Last Post: 18-01-2008, 11:54 PM
  4. How to Find if i have K jet or a Digifant golf GTI
    By Zelf1 in forum Golf MK2 - 1984 - 1992
    Last Post: 26-12-2007, 11:18 PM
  5. how do i find out what BHP my mk4 golf TDI is?
    By kyleb in forum Archive posts
    Last Post: 31-10-2007, 12:29 PM
