Thread: AllRoad 2005 collapsed front suspension
Results 1 to 10 of 13
  1. AllRoad 2005 collapsed front suspension
    Jun 2019
    Braintree
    Hello there new to site and looking for help/ information.first of all this is my friends car the problem is the both front wheels are buried into the arches and n/s rear is a lot lower than o/s rear this happen while driving off-road there was a loud thumb or bang probably hit something underneath? Said I would look at it was thinking air line damage but surely shouldn't put the fronts into the arches and would just drop to the lowest ride height?.I know nothing about this type of suspension but very capable mechanically.
  2. Re: 2006 A6 allroad Quattro collapsed suspension
    Jul 2013
    76 Post(s)
    The first thing to do is Google audio SSP 292 or 243 this will give you a good overview on the system.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: 2006 A6 allroad Quattro collapsed suspension
    131 Post(s)
    1973 Post(s)
    You will need VCDS or similar to be able to work on it, if the compressor is locked out you have to clear the code before it will run again.
  4. Re: 2006 A6 allroad Quattro collapsed suspension
    Jun 2019
    Braintree
    Ok thanks for the information (sorry its a 2004 model but the same) looking at it on Saturday can't even turn the key at mo as front wheels are jammed into the outside edge of arches and holding the steering lock on hard ( a bit of muscle should sort that) the suspension must have dropped after turning off as there is no way it could have been driven. thanks dan have a better idea of how this operates now as for vcds is there any plug in hand held scanners that are up to the job if not what version of vcds do I need?.car has been used for years as a farmyard run around and paying the price did tell her if you need to go in the rough stuff get a land/range rover.
  5. Re: 2006 A6 allroad Quattro collapsed suspension
    Aug 2016
    Cape Town, South Africa
    If it's a 2004 model, are you sure it's a C6 and not a C5? Fairly different air suspension setups between the two.
    Whilst the air struts on the C6 are not without fault, the ones on the C5 are notorious. If it's a C5 and it's still on it's original air bag's then your friend was already on borrowed time.
    2006 A6 Avant 3.0 TDi Quattro
  6. Re: 2006 A6 allroad Quattro collapsed suspension
    131 Post(s)
    1973 Post(s)
    Yes, that will be a 4B (C5 if you must use that confusing nomenclature) not a 4F, look at the VIN and it will be wauzzz4Bx4N??????, a type 4BH . The one my business partner owns (2005) I once drove from the previous owners home back to the workshop with the front suspension completely deflated, it can be done with care.
  7. Re: 2006 A6 allroad Quattro collapsed suspension
    Jun 2019
    Braintree
    It's an A6 at least that what the mot history says and made interesting reading plagued by front suspension failures and rear shocks show little effect.reading through the information each air bag unit keeps 3.5 bar of min pressure via a valve so 3 units have burst?.will know more over the weekend will let you know the result.
  8. Re: 2006 A6 allroad Quattro collapsed suspension
    131 Post(s)
    1973 Post(s)
    Yes we now it is an A6 but which one, 4B or 4F? Look at the VIN as I described above.
  9. Re: 2006 A6 allroad Quattro collapsed suspension
    Jun 2019
    Braintree
    Ok got it now vin says wauzzz4b15n****** .got it started and suspension lifted after a while can hear a compressor? keep coming on at the back just Infront of fuel tank n/ s (loud) then a momentary sharp pressure release when it stops sits there for a while then back drops a little with hissing and process repeats.also level switch has 4 settings will only go to the 3rd.now parked up will check tomorrow but expect it to have dropped all the way down. Air bags?.
  10. Re: 2006 A6 allroad Quattro collapsed suspension
    131 Post(s)
    1973 Post(s)
    So it is a 2005 4B AKA a C5, I will move the thread....
  1. 2005 allroad front brakes issue
    By quattrogary in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-07-2017, 10:29 PM
  2. 2005 2.5tdi allroad front pad size
    Last Post: 02-05-2017, 02:59 PM
  3. a6 allroad front suspension rattle
    By chris.d in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-02-2016, 06:23 PM
  4. Allroad Front Suspension Parts
    By stewartbuckland in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-01-2009, 08:04 PM
