Thread: A3 Coolant and Coolant Hoses
Results 1 to 10 of 10
  1. A3 Coolant and Coolant Hoses
    Dec 2018
    Norfolk
    Hey all,
    A quick question, the Haynes Manual suggests using G12 which isn't sold anymore. I've gone onto Halfords and they suggest using the G40 which is blue, not pink.
    Comma G40 Antifreeze and Coolant RM...
    My car is 2004, 2L FSI which currently has the pink coolant. Is the Halfords G40 the right coolant even though it's blue?
    Also I need to buy a new reservoir and the coolant return hose as they have corroded and each of them are broken. Am I corrected in thinking that is the name of the hose or is it called something else? It's the hose in the red circle below.
    Thank you.
  2. Re: A3 Coolant and Coolant Hoses
    Near Blackpool
    48 Post(s)
    TPS will have both. Give em a bell with your reg
  3. Re: A3 Coolant and Coolant Hoses
    Mar 2016
    Minervois, France
    54 Post(s)
    Prior to G12, the standard VAG antifreeze was G11, which is blue, and has not been generally available for some years. The last time I managed to buy it for my van was 2014, when I found some in Germany. I have now changed it over to G13.
    If your coolant is pink it is probably G12, G12 Plus, G12 Plus Plus, or G13, which are successive replacements for G11, and only miscible with each other.
    None of these replacements may be mixed with G12, and the system has to be flushed thoroughly with clean water before they can be used.
    Unless Halfords will give you a written guarantee that their G40 is miscible with VAG G11, I would recommend you flush the cooling system and use G13 from a VAG dealer.
    My Audi has G13, and I also use it for our Alfas, so we have the same antifreeze in all the vehicles.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: A3 Coolant and Coolant Hoses
    130 Post(s)
    1972 Post(s)
    It is G13 now which is purple.
  5. Re: A3 Coolant and Coolant Hoses
    Near Blackpool
    48 Post(s)
    My A3 was pink, now purple but wasn’t flushed.... Hope pink and purple mix ok as it looks red now
  6. Re: A3 Coolant and Coolant Hoses
    Mar 2016
    Minervois, France
    54 Post(s)
    I'd say mauve myself
    Whether the concentrate is considered to be purple, mauve, or pink, when diluted it's a pale pink colour when seen through plastic header tank, and cannot be confused with blue G11.
  7. Re: A3 Coolant and Coolant Hoses
    130 Post(s)
    1972 Post(s)
    That is because you live in French land and the frogs instinctively cannot bear to agree with anything the English say, we say British Racing Green and they say it should have been proper green and we cheated....
  8. Re: A3 Coolant and Coolant Hoses
    Mar 2016
    Minervois, France
    54 Post(s)
    1 1 0
  9. Re: A3 Coolant and Coolant Hoses
    130 Post(s)
    1972 Post(s)
    Mrs Crasher says it is pink and I think it is purple because I am colour blind which is true.....
  10. Re: A3 Coolant and Coolant Hoses
    Near Blackpool
    48 Post(s)
    Pinky-Purple?
  1. Replies: 6
    Last Post: 29-11-2018, 01:41 PM
  2. Replies: 6
    Last Post: 30-08-2017, 09:04 PM
  3. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  4. Car Plan Red Advance Anti-Freeze & Coolant Supplied as G12++ Coolant
    By Vindictive in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 04:12 AM
  5. Coolant hoses
    By golf96 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-12-2007, 09:16 PM
