Thread: Timing Belt Hydraulic Tensioner/Damper
  1. Timing Belt Hydraulic Tensioner/Damper
    Feb 2019
    Surrey
    Should the hydraulic tensioner/damper be changed when the timing belt is changed? I see that some timing belt kits include the hydraulic tensioner/damper, and some don't.
    1997 A4 1.8T
  2. Re: Timing Belt Hydraulic Tensioner/Damper
    130 Post(s)
    1972 Post(s)
    It does not have to be changed, if it is not leaking and still works then you can take a chance on it.
  3. Re: Timing Belt Hydraulic Tensioner/Damper
    Mar 2016
    Minervois, France
    54 Post(s)
    In about 2008, Continental replaced the original hydraulic tensioning pulley in their kits with a mechanical pulley tensioned by a spring.
    This information is on the forum - somewhere - I copied it and saved the Continental bulletin, but didn't bookmark the post.
    I just found the information HERE
    EDIT: Link for the PDF of the information is at the bottom of the page.
    The old kit part no. is CT 909 K5, the new one is CT 909 K10.
    Also, when replacing my timing belt kit (I fitted the hydraulic tensioner before I found out about the update), I found that the tensioner pulley previously installed did not line up with the belt.
    It was exactly the same design, but had a built-in 6 mm spacer on the back instead of a 3 mm one, so the belt was riding partly off the pulley.
    My supplier had both pulleys, so I was able to exchange for the correct one.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: Timing Belt Hydraulic Tensioner/Damper
    130 Post(s)
    1972 Post(s)
    If it still has the pre 5/99 system with the horrid adjuster these had then I would convert the later system using an VAG kit number 058 198 119 and damper 058 109 479 B. I looked at doing the friction damper conversion on Mrs Crashers 2006 Polo GTI as oddly it still used the later hydraulic conversion. My Octavia had the late hydraulic system but when I bought the fuel exchange engine is was fitted with the friction system which I continued with six years later when I did the cam belt.
  5. Re: Timing Belt Hydraulic Tensioner/Damper
    7 Post(s)
    This is interesting.
    The Wifies 2001 Golf with an ASZ has the hateful damper setup.
    I did try and see if I could convert to the later friction setup as fitted to my AWX engined Passat but it would have required a new hole drilled and tapped in the block. That was a big nope on the transverse engined Golf.
    So.... is there an aftermarket kit for the ASZ?
    Brilliant news if there is. The belt is due soon'ish and I always dread doing these, especially due to the sodding engine mount!
  6. Re: Timing Belt Hydraulic Tensioner/Damper
    130 Post(s)
    1972 Post(s)
    The ole is in the head, stick with the hydraulic system, by the next time it needs one, the car will be history.
  1. Cam belt tensioner Linten or hydraulic
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-11-2018, 07:04 PM
  2. 2004 1.9 130 AVF engine, does it have a damper for the timing belt tensioner?
    By AliBailey88 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2014, 10:32 PM
  3. Cam belt tensioner damper, correct setting please.
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2010, 12:07 AM
  4. Leaking cam belt hydraulic damper?
    By Last Triumph in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2009, 06:03 PM
  5. How To Dunnit. 1.8T Timing belt, tensioner,damper, pump.
    By kje in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2008, 09:00 PM
