Thread: A4 B7 2.0 TDI starting issue
  1. A4 B7 2.0 TDI starting issue
    Feb 2019
    Glasgow
    Hi there, wondering if anyone could help me or has had a similar issue.
    A week ago I went out to my car and the battery was flat. I got a jump start and the car started no problem. I then drove 30 seconds to a junction and car cut out when pulling away (it is possible I stalled). I then got another jump start and the car wouldn’t start with a jump start. I tried two different cars to jump start and the car would turn over and wouldn’t fire up.
    I replaced the battery as I thought maybe a dead cell and still wouldn’t fire up. I checked all fuses and all were ok, however wasn’t getting power to fuel pump fuse so done a bit of research and decided to replace the fuel pump relay. I opened the ECU compartment in the engine bay and it was full of water. So I decided to change the fuel pump relay (614) and the other relay in there that looked very corroded (395). I tried firing up and still nothing. The car just turns over and won’t fire up.
    I have tried tracing wiring and checking various other relays and still cannot find anything.
    If anyone has any other suggestions on things I can check/try, or something stupid that I am missing, it would be much appreciated.
  2. Re: A4 B7 2.0 TDI starting issue
    Oct 2017
    Kegums, Latvia
    Can You elaborate about how it doesn't start - does it crank? Did You try towing it with other car to start? Are You getting fuel to injectors?
    Sent from my Pixel 2 XL using Tapatalk
  3. Re: A4 B7 2.0 TDI starting issue
    130 Post(s)
    1972 Post(s)
    Check for fault codes, if there are none, use measuring blocks to check for an RPM signal. As a note, it is extremely unwise to jump start from/to a modern car, you can spike both cars and end up with a big bill.
  4. Re: A4 B7 2.0 TDI starting issue
    Apr 2022
    Sheffield
    Quote Originally Posted by davemurty1 View Post
    Hi having same problem did you ever fix it
  1. car starting issue
    By churp in forum Touran - Sharan - Caravelle
    Last Post: 07-08-2016, 02:43 PM
  2. 2.0 TDI 170 starting issue
    By Territouran in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-05-2015, 05:57 PM
  3. Starting issue
    By don87 in forum Leon
    Last Post: 17-03-2011, 07:46 PM
  4. Please Help Starting issue A4 1.9 TDI 90
    By Connor_Scotland in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-12-2010, 12:22 AM
  5. Hot starting issue
    By orangejohn in forum Chat - Anything with wheels
    Last Post: 05-09-2008, 11:00 PM
