Thread: A4 b8 brake discs
Results 1 to 10 of 14
  1. A4 b8 brake discs
    Mar 2012
    england
    How will I find out 100% what size discs are on my Audi A4 b8 I been on Euro car parts there is 3 sizes Mtech brake there is 2
    Can’t be that maybe for one car surly
    Cheers Matt
  2. Re: A4 b8 brake discs
    Oct 2012
    Estonia
    64 Post(s)
    You have pr codes in your sticker in service book or around spare wheel, follow those by online catalogue!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: A4 b8 brake discs
    Mar 2012
    england
    Ah ok I will look cheers
  4. Re: A4 b8 brake discs
    Apr 2009
    I had to order both sets for mine and return the incorrect set
    Sent from my MI 6 using Tapatalk
    Audi A4 Avant 2.0 TDi 2009
  5. Re: A4 b8 brake discs
    Mar 2012
    england
    That’s what I’m trying to aviod tbh
  6. Re: A4 b8 brake discs
    Feb 2019
    London (SW), UK
    If you look on www.oemepc.com you can search by VIN to see what brakes are right for you. Just be aware there could be in-model variations depending on your engine size, fuel type, trim line etc
    You want to look for a part that usually begins with a "1". For example on my S5 my my rear brakes are 1KE and fronts 1LJ.
    As mentioned above, you can also look on the silver sticker with all the codes. From memory, rear brakes are the 7th code and front the 9th.
  7. Re: A4 b8 brake discs
    Mar 2012
    england
    That’s brilliant I will look but could Audi tell me exactly if I called up and asked ?
  8. Re: A4 b8 brake discs
    Feb 2019
    London (SW), UK
    Yes, they should if you give them your VIN.
  9. Re: A4 b8 brake discs
    Mar 2012
    england
    Perfect spoke to Audi and they gave me the correct size discs front and back now just need to order them
  10. Re: A4 b8 brake discs
    Mar 2012
    england
    All ordered now should be here next week what do I have to watch when I change them I know about release of the parking brake though vcds
