Thread: How to tell between BMM/BMP and BKP engine...
  1. How to tell between BMM/BMP and BKP engine...
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    From what I can gather the BMM/BMP 2.0 TDI engines did not have injector issues, whereas the BKP notoriously does.
    Is there an easy way to tell the difference? As my B6 is a 2007 model it could have either according to Wikipedia.
    Thank you in advance!
  2. Re: How to tell between BMM/BMP and BKP engine...
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by jmurray01 View Post
    In the boot under the carpet / spare wheel hatch should be a white sticker with codes on it. It tells you all you need to know including engine and gearbox code.
    If it has a hand written code on it of 23H9 then the injector recall was done. This may be written in the service booklet if you have it.
    Mad Mitch
  3. Re: How to tell between BMM/BMP and BKP engine...
    131 Post(s)
    1973 Post(s)
    The BMM was never used in the 3C and the BMP only used from 05/07 to 11/08 on cars with a DPF.
  4. Re: How to tell between BMM/BMP and BKP engine...
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    So it'll definitely have the BKP then... Better call the local VW dealer on my next holiday to see if it has had the unofficial recall or if I'll have to get that done out of my own pocket! If I do then I'll get them done same time as the timing belt, but I'd rather not have to!!
  5. Re: How to tell between BMM/BMP and BKP engine...
    131 Post(s)
    1973 Post(s)
    The Siemens injector recall on the BKP and BMN was a “Campain” by VW and not an official recall and has LONG expired.
  1. Replies: 1
    Last Post: 13-04-2016, 02:22 PM
  2. Replies: 3
    Last Post: 10-05-2012, 04:14 AM
  3. Question Knocking sound (inconsistant) on acceleration from engine (1995 Audi Coupe 2.0E - ABK engine)
    By Jonnovision in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-11-2010, 07:51 AM
  4. Question Engine problem - Engine speed sticks high / Unstable engine speed
    By sef-75 in forum Bora - 1998 - 2005
    Last Post: 29-09-2009, 09:52 PM
  5. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
