Thread: Engine Management Light Flashing
Results 1 to 10 of 19
  1. Engine Management Light Flashing
    Feb 2019
    Salisbury
    Hi everyone,
    I need your advice please. Yesterday and today my 2011 bluemotion 1.6 tdi golf decided to display a engine management light which kept flashing until I turned off the engine. There seems to be a drop in power too. I don’t have access to a error code reader so I just wondering if anybody has had similar issues before. I’m guessing I have to take it to a garage but need just want a heads up to what I could expect it to be. It’s on 56k.
    Cheers,
    Brenden
  2. Re: Engine Management Light Flashing
    Jun 2016
    Glasgow
    Quote Originally Posted by Brendzer View Post
    Hi everyone,
    Cheers,
    Brenden
    Could be loads of things. Get it checked.
  3. Re: Engine Management Light Flashing
    Feb 2019
    Salisbury
    Quote Originally Posted by vag_tech View Post
    Yeah I call my local VW specialist tomorrow and see when they can check it out. Would you recommend still driving the car until then or would this be a bad idea if it’s something big gone wrong? I know it could be a lots of things...but if I took it easy?
  4. Re: Engine Management Light Flashing
    Jun 2016
    Glasgow
    Pay attention to drivability. If it’s in limp then it’s very unlikely to do damage but could present issues getting there. So use your judgement and proceed with caution, paying attention to engine behaviour and emissions.
    If you have AA or RAC home start / recovery, this is the safe and responsible option...however perhaps is overkill. If in doubt or not confident, play safe I’d say.
  5. Re: Engine Management Light Flashing
    130 Post(s)
    1972 Post(s)
    With a CAYB or CAYC code engine you can almost guarantee this will be EGR valve failure, do you know if the emissions recall has been done as this is known to cause what was already a highly failure prone compnet to be even more unreliable.
  6. Re: Engine Management Light Flashing
    Feb 2019
    Salisbury
    Thanks for message yeah I don't know about if its had the emissions recall, I get in touch with VW and see (I only brought the car 4 months ago from a used car garage). I managed to get hold of a VAG cable and done a scan this morning - is there any clues it could be a EGR valve failure from the results?
    Saturday,23,February,2019,11:35:44:39744
    VCDS Version: 18.9.1.0 (x64)
    Data version: 20190114 DS296.0
    Ross-Tech: Home
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
    VIN: Mileage: 91250km-56700miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 MN HW: 03L 907 425 C
    Component: R4 1.6l TDI H43 9979
    Revision: --H43--- Serial number: 00000000000000
    Coding: 08114014030501080000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM16TID02103L906023MN 003014
    ROD: N/A
    VCID: 7EF425BAE16C35BAAF-802A
    No ASAM data for: "EV_ECM16TID02103L906023MN" (VW36 *)
    2 Faults Found
    7563 - ROD - Unknown Error Code
    - 00 [101]
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91234 km
    Date: 2019.02.16
    Time: 17:46:16
    7343 - ROD - Unknown Error Code
    - 00 [175]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Mileage: 91256 km
    Date: 2019.02.17
    Time: 20:31:15
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 133B200D092200FFC81204EB90220091310000
    VCID: 7BF22CAEFA7E209288-802E
    No fault code found.
    Address 08: Auto HVAC (J301) Labels:. 3C8-907-336.clb
    Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
    Component: AC Manuell H19 0304
    Revision: 00001016
    Coding: 0000004003
    ASAM Dataset: EV_ACManueHBBVW36X A01010
    ROD: N/A
    VCID: 7F0AD8BEE6663CB2A4-802A
    No ASAM data for: "EV_ACManueHBBVW36X" (VW36 *)
    Address 09: Cent. Elect.
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
    Component: AirbagVW10 013 0613
    Serial number: 003G5RA9E7GL
    Coding: 00004432
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 316ECE8660B21AC262-8064
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME15645162ZZZN
    Crash sensor for side airbag: front passenger side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME7D0F6662ZZZ6
    Crash sensor for side airbag: rear: driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME4C545B47ZZZ0
    Crash sensor for side airbag: rear: passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME7E325A4BZZZ5
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5K0 920 972 A HW: 5K0 920 972 A
    Component: KOMBI H03 0607
    Coding: 470B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 2E54D5FA718C053A7F-807A
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 J HW: 1K0 907 951
    Component: J533 Gateway H43 1620
    Revision: H43 Serial number: 090811F1001263
    Coding: 350003
    VCID: 377AF09E86D6C4F22C-8062
    Address 25: Immobilizer
    Cannot be reached
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
    Component: Tuer-SG 009 2120
    Coding: 0131636
    VCID: 316ECE86A8B21AC262-8064
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 69 3201
    Revision: 00H20000
    VCID: 3460C79257A02FEA09-8060
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 156 A HW: 5K0 035 156 A
    Component: Radio 553 0555
    Revision: R0553006 Serial number: VWZ5Z1L0570359
    Coding: 0000020002
    VCID: 25462AD62C7A46628E-8070
    1 Fault Found
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 86753 km
    Time Indication: 0
    Date: 2013.04.18
    Time: 00:00:44
    Address 61: Battery Regul. (J840) Labels: Redir Fail!
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 1620
    Coding: 030B185A
    VCID: 71EE0E86A8325AC222-8024
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Serial number: 00000000008900343661
    End-------------------------(Elapsed Time: 01:52)--------------------------
  7. Re: Engine Management Light Flashing
    May 2009
    London UK / Istanbul TR
    From the scan ROD means unknown error code, current version of VCDS dataset unable to identify the fault in ÉCU. If you repeat scan after updating VCDS software, you get the actual fault. Google search on fault 7343 relates to EGR sensor.
    2010 Golf 6 Highline 1.4 TSI 122 DSG Sunroof Candy White
  8. Re: Engine Management Light Flashing
    130 Post(s)
    1972 Post(s)
    18.9.1 is the latest release....
  9. Re: Engine Management Light Flashing
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    I have loads of ROD - Unknown Error Code. They still show with the latest software.
    There are loads of threads on the Ross-Tech forum.
    Possible Cause:
    Possible bug in VCDS software that will be fixed on the next issue.
    Unknown
    Error Code
    2012 Passat SE TDI - Unknown Error Code
    29-12-2017 Not finding a ROD file is not unusual when modules that don't belong in a particular car get retrofit. I'm confident we can make a work-around for this once we're back in the office next week.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  10. Re: Engine Management Light Flashing
    Oct 2017
    London
    12 Post(s)
    I only ever seen the ROD when I was using a cheap Ebay copy of VCDS. Never seen it again since I seen the light and bought the genuine version, like I should have done from the start.
    1 1 0
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2020, 07:34 PM
  2. Please Help Flashing Engine Management light
    By Larry McG in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-02-2016, 05:40 PM
  3. Flashing engine management light
    By delv6 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2009, 08:48 PM
  4. Flashing Engine Management Light
    By hibeenation in forum The Commercial Range
    Last Post: 26-11-2007, 09:21 PM
  5. engine management light flashing
    By SMOKINGZULU in forum A2
    Last Post: 04-06-2006, 09:54 AM
