Thread: Air con service needed @ 3 years old? Why so much??
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. Air con service needed @ 3 years old? Why so much??
    Jul 2016
    Hampshire
    Hi all
    My A6 is currently having it's 3 year service carried out, plus brake fluid change. The dealership recommended an air con service at £149 as this should be done every 2 years - what is the consensus on this advice and is £149 a fair price? Seems a lot even for Audi.
  2. Re: Air con service needed @ 3 years old? Why so much??
    Mar 2018
    GB
    19 Post(s)
    Car Air Conditioning Repairs, Recharges, Diagnostics, Service
    They come to you and £70.00 was the last charge I paid, if John doesn't cover your area he'll possibly recommended someone, lots of useful information on the website as well.
    Sent from my SM-G950F using Tapatalk
  3. Re: Air con service needed @ 3 years old? Why so much??
    Jul 2016
    Hampshire
    Thanks for the information Bill. So Audi aren't doing anything Audi-specific than an independent couldn't do?
  4. Re: Air con service needed @ 3 years old? Why so much??
    Mar 2018
    GB
    19 Post(s)
    They're not aircon specialists, but do not go somewhere they say they'll top it up, you need a specific amount of lube and coolant checked by downloading into a vacuum.
  5. Re: Air con service needed @ 3 years old? Why so much??
    Apr 2014
    Derby
    30 Post(s)
    They are trying to up sell you. Its a ridiculous price for what is involved. Makes my blood boil how dealerships try to rip you off, and by inference think you are a mug. At most it is the air con filter, and they may test gas pressures etc, but should be ok after 3 years, and you only tend to do that when you feel the air con is not so cold as it once was.
    Current Fleet
    2017 Audi A6 Avant BiTdi
    2008 BMW Z4M Roadster
    2003 Clio 172 Cup
  6. Re: Air con service needed @ 3 years old? Why so much??
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi assuming it is over 3 years then Audi fixed price service is ( 2L and under )
    interim service £170 Major £338 Air-con £90 Brake fluid £65 do not see why the air needs doing every 2 years, my 2003 TT has never had one done and works fine at 15 years old.
    Question there pricing, I would.
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  7. Re: Air con service needed @ 3 years old? Why so much??
    Jul 2016
    Hampshire
    Quote Originally Posted by Elansear View Post
    Mine is a 3.0L engine. Would they charge more for air-con work just because it's a larger engine?!?
  8. Re: Air con service needed @ 3 years old? Why so much??
    Mar 2018
    GB
    19 Post(s)
    Mate unless its not cold don't worry turn it on once a month it clears a misty screen lovely just run it to lube the system and seals and if it stops working contact a specialist.
  9. Re: Air con service needed @ 3 years old? Why so much??
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi looking at Essex and M25 Audi web site the following for over 2L
    IS £203 MS £409 Air £79 BF £ 65
    also same prices at Lookers Audi
  10. Re: Air con service needed @ 3 years old? Why so much??
    Jul 2016
    Hampshire
    Hmm, my car is at a Lookers dealership. Anyway, I'm leaving it for now and the rep rang me to discuss some other issues and didn't push the air-con service. Turns out those Bose speakers can't handle the volumes I put thru them, both fronts being replaced under warranty thankfully
  1. Replies: 6
    Last Post: 22-08-2017, 09:28 PM
  2. Audi Finance - 2 years service trick
    By tribloke in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-12-2013, 12:35 PM
  3. Attention VW - 3 years service for £250!
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-09-2010, 12:10 AM
  4. Replies: 3
    Last Post: 21-10-2008, 06:28 PM
  5. 25 Years of the Quattro - The early years
    Last Post: 29-03-2005, 09:16 PM
