Thread: Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cooler?
  1. Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cooler?
    Jun 2016
    falmouth
    Heya, thanks for looking at my thread.
    My sisters MK4 golf has oil in coolant but no coolant in oil. Combustion gas in coolant test showed present combustion gases. With the gases in the coolant can it still just be the oil cooler? Or is it now definitely either: head gasket or cracked head or leaking exhaust manifold gasket?
    Cheers!
    Mike
  2. Re: Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cool
    130 Post(s)
    1972 Post(s)
    It would be nice to know which engine it had?
  3. Re: Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cool
    Jun 2016
    falmouth
    Heya Crasher,
    Oh yeah it would... It's a TDI but I'm not sure what the engine code is.
    Cheers!
    Mike
  4. Re: Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cool
    130 Post(s)
    1972 Post(s)
    If it is a 115, 130 or 150 PDTDI, these are prone to head gasket failure, especially the 115PS.
    1 1 0
  5. Re: Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cool
    Jun 2016
    falmouth
    Thanks for that, can I rule out oil cooler considering there's combustion gases in coolant?
    Also can you let me know how you'd find out if it is the exhaust manifold gasket leaking instead of the head gasket?
  6. Re: Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cool
    130 Post(s)
    1972 Post(s)
    To see oil in the coolant from a head gasket leak is very rare, I simply cannot remember the last one. To misdiagnose combustion gases in the coolant using the usual chemical dye kit from Snap Off is common, I sometimes think it would say there are combustion gases in fresh water and the VAG coolant bottle seems to make it impossible to take a good sample without pulling coolant in which gives the same result as combustion gases. The PD TDI only tends to show head gasket issues under load such as on the motorway and it blows all the coolant out, oil coolers fail all the time.
    1 1 0
  7. Re: Oil in coolant but no coolant in oil. Combustion gas in coolant test showed present gases. With the gases in coolant can it still just be oil cool
    Jun 2016
    falmouth
    Thanks for the brilliant reply Crasher, even when you think you've done the sensible thing testing; it turns out that you can't be sure even then. Some times it seems like practicing voodoo is more of a certain art. I'll pass the info on to my sister and recommend we just go ahead with the oil cooler replacement / full coolant flush and see how she goes.
  1. Replies: 6
    Last Post: 30-08-2017, 09:04 PM
  2. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  3. Car Plan Red Advance Anti-Freeze & Coolant Supplied as G12++ Coolant
    By Vindictive in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 04:12 AM
  4. Looking for loan of coolant/combustion test kit
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-02-2011, 09:21 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
