Thread: Adblue System Fault - No Restart 1000km
Results 1 to 10 of 16
  1. Adblue System Fault - No Restart 1000km
    Dec 2016
    Ireland
    Hi Folks,
    I could use some help, I have what appears to be a pretty serious problem with my car. On the motorway I got a fault, "Adblue System Fault, no restart in 1000km. When I got home I did a scan with an OBDeleven and got the following error code.
    01 Engine
    System description: R4 2,0L EDC
    Software number: 04L906021FE
    Software version: 8243
    Hardware number: 04L907309
    Hardware version: H23
    ODX name: EV_ECM20TDI01104L906021FE
    ODX version: 002007
    Long coding: 0A194012242401080000
    Trouble codes:
    P204F00 - Reductant System Performance Bank 1
    static
    I had just put in adblue 2 days before I got the error, but I topped it up again and made sure it was completely full. I reset the error code and drove for 100km. The error code above did not return, but the adblue countdown has continued and is now at 800km. I also tried a hard reset on the reductant control module, the original error was on the engine module, but I wasn't sure if hard resetting that is a good idea.
    I'm reading some horror stories about what this error can be, some people have paid upward of 2K to get NOX sensors and other parts replaced. Anybody got any ideas before I get the vaseline and go to the dealership?
  2. Re: Adblue System Fault - No Restart 1000km
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    I have just had this fault on my 2015 A6 Allroad, for me it was the reductant pump that was at fault. It was replaced and problem solved. Cost for the pump was £600 supplied. I was told it could take up to 4 weeks for the pump to be supplied, it took 3 days.
    Mine was P208B Implausible Signal
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  3. Re: Adblue System Fault - No Restart 1000km
    Feb 2016
    53 Post(s)
    There was talk of possible wiring fault, but after testing it was confirmed to be the pump.
  4. Re: Adblue System Fault - No Restart 1000km
    Dec 2016
    Ireland
    Thanks. I find it hard to believe its a part failure just after I topped up the tank, but I know that's what Audi are going to say too.
  5. Re: Adblue System Fault - No Restart 1000km
    Feb 2016
    53 Post(s)
    Mine went and I hadn't even topped up the tank, only had the car since August, pump went beginning of October. Is your car still under warranty?
  6. Re: Adblue System Fault - No Restart 1000km
    Dec 2016
    Ireland
    Nope, mine's a 2014, so well out of warranty
  7. Re: Adblue System Fault - No Restart 1000km
    Feb 2016
    53 Post(s)
    Do you have a local trusted independent that you could use? It was an indy that sorted mine out.
  8. Re: Adblue System Fault - No Restart 1000km
    Dec 2016
    Ireland
    I do have a good VAG specialist indy I use, I'll call tomorrow, it's a bank holiday weekend here. Typical! It's a 200km round trip to them though, but I might just chance it
  9. Re: Adblue System Fault - No Restart 1000km
    Dec 2016
    Ireland
    I took the car to the Indy I normally use and he said this combination of trouble code and adblue error is a known software glitch, and a SW update on the ECU is the fix, 20mins later the ECU was updated, the error was gone and I was on my way. So far I've done 120km and no re-occurence, so all looks good.
    0 3 0
  10. Re: Adblue System Fault - No Restart 1000km
    Jun 2019
    Hi Silane, I have exactly this fault on my 2014 A6 Avant, and the same error code so your post does suggest the same cause for my car. Could you just update on whether the ECU software update resolved the problem permanently? Thanks!!
  1. 2015 Allroad Adblue Fault
    By KevTrem in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-10-2018, 08:24 AM
  2. Adblue fault
    By PaulSpence in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-01-2017, 11:07 PM
  3. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  4. Replies: 4
    Last Post: 17-09-2008, 09:01 AM
  5. fault codes + loss of power until engine restart
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-06-2008, 12:15 AM
