Thread: 1.6 TDI 02/2010 when should it get timing belt? What oil?
  1. 1.6 TDI 02/2010 when should it get timing belt? What oil?
    Sep 2008
    Highlands
    12 Post(s)
    Hi All
    what is the recommendation time/ miles for changing timing belt on my 2010 1.6 TDI ?
    also what oil is everyone using for non long life services?
    anything else advisable doing when belt is changed?
    thanks for any help
    vince
  2. Re: 1.6 TDI 02/2010 when should it get timing belt? What oil?
    May 2012
    Everywhere
    308 Post(s)
    Oil !
    The universal highest spec VW oil , 507.00 .
  3. Re: 1.6 TDI 02/2010 when should it get timing belt? What oil?
    Sep 2008
    Highlands
    12 Post(s)
    Cheers Gaz
    what about timing belt interval ?
    vin
  4. Re: 1.6 TDI 02/2010 when should it get timing belt? What oil?
    Jan 2018
    Sussex
    55 Post(s)
    5 years or 111 k miles for 2009 model or 130k miles for 2010 model up, if OEM parts used.
    Dont forget Water pump as some don't change it and it starts to leak.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  5. Re: 1.6 TDI 02/2010 when should it get timing belt? What oil?
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Oil change interval non long life time/distance 10,000 miles or 1 year which ever comes first. Long life 20,000 miles or 2 years which ever comes first. VW 507.00.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  6. Re: 1.6 TDI 02/2010 when should it get timing belt? What oil?
    Sep 2007
    HI all,
    to dig up an old thread....I'm looking at buying a 1.6tdi bluemotion mk6 golf (2012). It has FSH and looks in very good condition. before making my final offer though I wanted to know if the timing belt will need changing as it's coming up to 130k? From this thread it suggests that it is coming up for replacement?
    Any ideas on rough cost to have this done so I can use this to bargain with?
  7. Re: 1.6 TDI 02/2010 when should it get timing belt? What oil?
    Jan 2010
    uk
    Quote Originally Posted by bobsy852 View Post
    HI all,
    I got mine changed for a 1.6 TDi after 6 years on 24k miles. paid £450 for a full timing belt kit change including water pump, tensionsers , alternator belt and oil and filter change. That was at an independent VW specialist about a couple years back if that gives you an idea re costs.
    Golf mk6 (2010) 1.6S TDI (105) 5 Door Shadow Blue
    Alloys, Sunroof, Fogs, 310 Radio+MDI, Highline, Mats, Service Plan, GAP+Smart Repair.
  1. Timing belt change on 2010 2.0tdi Black Edition
    By Rayscriv in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-10-2015, 07:41 PM
  2. 2010 Passat Timing Belt Question
    By kop77audi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-06-2014, 09:06 PM
  3. 2010 (March) - 1.8 TFSI - Timing Chain or Belt?
    By _tones in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-12-2013, 06:58 PM
  4. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  5. Changing the timing belt and drive belt on Audi A6
    By Robbromilow in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2009, 08:00 PM
