Thread: Golf Mk4 battery drain
Results 1 to 10 of 14
  1. Golf Mk4 battery drain
    Sep 2018
    tunbridge wells, uk
    Hello all
    I'm Chris, new to the forums
    I own a 2000 AGR Golf Mk4 TDI and have had battery drain problems for some time.
    I've done quite a bit of reading, and fiddling, to fix it but no luck so far, so looking for advice on next steps.
    At first I thought, faulty door locks, and have replaced the two that were obviously problematic (intermittently not locking, or didnt trigger the interior lights when doors opened). These I've replaced and the associated problems are gone, but the battery drain continues.
    I've inspected the wires around the boot opening and these seem fine.
    The drain looks to be coming from fuse 14. Should I replace the other door locks in the hope that this will solve it? Does the CCM need replacing? There's nothing else obviously wrong with the car that suggests these things are faulty.
    Thanks in advance!
  2. Re: Golf Mk4 battery drain
    130 Post(s)
    1972 Post(s)
    Does it have the original radio?
  3. Re: Golf Mk4 battery drain
    Sep 2018
    tunbridge wells, uk
    Hey Crasher, yes it does.
  4. Re: Golf Mk4 battery drain
    Sep 2018
    tunbridge wells, uk
    I saw your posts on several other threads crasher and have followed your advice there too. One post suggested removing the plug to the CCM which I’ve done this evening. I won’t know what difference it makes until tomorrow though as the car battery is currently on charge. Car has been stood for a few weeks but I need to start using it again this coming week, so trying to get this all sorted.
    In that thread you were going to look and see what disconnecting the CCM might impact - did you ever find this out?
  5. Re: Golf Mk4 battery drain
    130 Post(s)
    1972 Post(s)
    Do you have or can you buy a multimeter with a 10amp current range.
  6. Re: Golf Mk4 battery drain
    Sep 2018
    tunbridge wells, uk
    I have one...
  7. Re: Golf Mk4 battery drain
    130 Post(s)
    1972 Post(s)
    Do you know how to do a current drain test at the battery earth terminal?
  8. Re: Golf Mk4 battery drain
    Sep 2018
    tunbridge wells, uk
    Yes. I have done this at terminal and at fuse 14 and believe that is the source. From memory it was 0.5a drain from this fuse. I will repeat the test tonight and check.
    If it is, what do you advise next?
    And if not?
    Thank you...
    Chris
  9. Re: Golf Mk4 battery drain
    130 Post(s)
    1972 Post(s)
    I need to check the wiring diagram at work
  10. Re: Golf Mk4 battery drain
    Sep 2018
    tunbridge wells, uk
    So this evening I ended up pulling every fuse out and checking the drain as I did so. Started at 0.36a with everything in place and gradually dropped to 0.29 with all the fuses out.
    Interestingly with all the fuses out, if I close and lock the driver door it drops the drain to 0.23a. That’s the lowest I can get it.
    From the battery top fuse box the drain is going through S176 from the linked image which says “relay panel”. Is this the fuse box?
    https://goo.gl/images/MWTJVf
    Help appreciated!
  1. vw golf mk5 annoying battery drain issue
    By evaldas7777 in forum VCDS - Help Requests
    Last Post: 10-12-2017, 07:24 PM
  2. Question Golf Mk5 battery drain when car Unlocked
    By Dvd dvd in forum Golf MK5 - 2004 - 2009
    Last Post: 10-11-2016, 11:27 PM
  3. Please Help Golf MK4 battery drain
    By lancisto in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2013, 08:25 AM
  4. Battery drain on Mk3 Golf Auto
    By ACMIRANGE in forum Golf MK3 - 1993 - 1999
    Last Post: 04-10-2011, 01:20 PM
  5. mk4 golf 1.9 tdi battery drain.
    By george@ggoudie. in forum Golf MK4 - 1999 - 2004
    Last Post: 15-04-2008, 12:35 PM
