Thread: Changing Throttle Body 2006 Touareg
  1. Changing Throttle Body 2006 Touareg
    Aug 2018
    Nottingham
    Hi all,
    I've got a Throttle Body that has the plastic gears worn out so i've ordered a repair kit (new gears) which i'm going to fit when they turn up but does anyone know if i need to re-calibrate this at all ? VAG-COM says it's stuck closed but it's actually stuck open (default by the spring) so just wondering if it'll need re-calibrating or will this "reset" itself ?
    Thanks in advance.
  2. Re: Changing Throttle Body 2006 Touareg
    128 Post(s)
    1967 Post(s)
    Which engine?
    DIRTY NICKEL
  3. Re: Changing Throttle Body 2006 Touareg
    Aug 2018
    Nottingham
    3.0 v6 tdi
  4. Re: Changing Throttle Body 2006 Touareg
    128 Post(s)
    1967 Post(s)
    I will assume it is a BKS code engine, fitting a new J338 is a fit and forget job but if you are rebuilding yours (how much is the repair kit?) I would at least want to do an output test on it before installation. The Elsawin barely even mentions it is there, just one line in the assembly diagram. £480 new from VW is taking the AdBlue..... Euro Car Parts is hardly any better! https://www.eurocarparts.com/search/422440860
    DIRTY NICKEL
  5. Re: Changing Throttle Body 2006 Touareg
    Aug 2018
    Nottingham
    Repair kit is £30 as it's just the 360 plastic cog and the half moon bit as the teeth have worn on mine. I don't think it'll be an issue but the VCDS thinks its stuck closed but it's actually stuck open so i'm obviously thinking that when i replace these bits and fit it then the car will STILL think it's closed when it's open so wasn't sure if it'll try and move it again and then register it's now working and open it fully or close it fully and reset itself.
    This is the kit : THROTTLE BODY REPAIR KIT AUDI VW 2.0 2.5 2.7 3.0 4.2 TDI A4 A5 A6 A8 Q7 TOUAREG | eBay
  1. Question help with throttle body fix
    By Rukks in forum Chat - Completely Off Topic
    Last Post: 28-06-2018, 05:17 PM
  2. Replies: 4
    Last Post: 06-06-2015, 12:57 PM
  3. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  4. Need Throttle Body DIY
    By HP88 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2011, 03:40 PM
  5. throttle body
    By slim1986 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-03-2008, 08:24 PM
