Thread: Dog guard inserts
  1. Dog guard inserts
    New Forest
    80 Post(s)
    I bought a Doguard Guardsman - Audi Q7 / SQ7 – mk2 – Dog Guard and Variable Boot Divider (part no. G1506B) from Guardsmen and I'm very happy with it. However, I appear to have loosened whatever is located in the inserts in the roof (inside)
    Anybody any ideas as to how I can loosen the plastic surrounds to sort them out?
    Sent from my SM-G965F using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  2. Re: Dog guard inserts
    New Forest
    80 Post(s)
    I'm able to get the plastic surrounds off okay, it's a clip-on, I can loosen the star-head bolt but I can't get the attached out of the roof lining.
  3. Re: Dog guard inserts
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    Removing
    Remove moulded headliner and lay it down on seats; headliner does not have to be removed.
    Press flap -2- towards rear, unscrew bolt -3- behind flap and detach retainer -1- for load guard.
  4. Re: Dog guard inserts
    New Forest
    80 Post(s)
    Quote Originally Posted by anemeth View Post
    Removing
    Hmm, I will have to remove the headliner. What a pain. Anybody done this? Do you have the details on removing the headliner anemeth?
  5. Re: Dog guard inserts
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    You have to remove "half of the car":
    Removing and installing moulded headliner
    Special tools and workshop equipment required
    t Removal wedge -T40233-
    Removing
    WARNING
    Observe safety precautions when working on pyrotechnic components → Chapter.
    – Remove A-pillar trim panels (top) → Chapter.
    – Remove B-pillar trim (top) on driver side → Chapter.
    – Remove C-pillar trim on driver side → Chapter.
    – Remove roof end trim → Chapter.
    – Remove D-pillar trim panels → Chapter.
    – Remove front roof module → Electrical system; Rep. gr.96; Controls; Removing and installing interior light/reading light (front).
    – Depending on equipment version: Remove cover for front camera → Anchor.
    – Remove sun visors → Chapter.
    – Remove centre bracket for sun visor → Chapter.
    – Remove grab handles → Chapter.
    W00-10994
    Equipment versions with panoramic sunroof:
    – Open sliding headliner.
    – Clean removal wedge -T40233- to avoid soiling moulded headliner.
    – Insert removal wedge -T40233- between frame -1- for panoramic sunroof and moulded headliner.
    – Release moulded headliner from frame for panoramic sunroof all round using removal wedge -T40233--arrows-, as shown in illustration.
    All vehicles (continued):
    – Move front seats as far forwards and down as possible and tilt backrests as far forwards as possible.
    – Fold down backrests (rear).
    – Depending on equipment version: Fold down rear seat backrests (3rd row).
    A70-12381
    – Move moulded headliner clear in vicinity of door seals on driver side.
    – Unclip moulded headliner -1- with trim -2- and support for trim from retainer for load guard -arrow-.
    – Repeat procedure on opposite side.
    A70-12382
    Caution
    t The moulded headliner is kinked very easily.
    t Kinked moulded headliners must be renewed.
    – Reach beneath moulded headliner and unclip centring pin -1- from body at rear -arrow-.
    Note
    Take out moulded headliner through rear lid opening.
    A70-12267
    – Lower moulded headliner at left side of vehicle.
    – Carefully take out moulded headliner through rear lid opening, as shown in illustration.
    – To do so, carefully guide edges of moulded headliner out through rear lid opening.
    1 1 0
  6. Re: Dog guard inserts
    New Forest
    80 Post(s)
    Might give that a miss
    0 2 0
  7. Re: Dog guard inserts
    Apr 2016
    berkshire
    39 Post(s)
    TBH though, personally I think the finish and quality of SOME of the NEW Q7 sucks like hell comparatively to the old version, for sure, a case of rock solid vs a a real bad work in progress :-0
    Sent from my STF-L09 using Tapatalk
  1. Fog light grill inserts
    By AlyM in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-03-2014, 10:00 PM
  2. Piano Black Inserts
    By Scooby-Doo in forum Passat CC
    Last Post: 07-01-2011, 09:40 AM
  3. AuDI I pod inserts
    By vinpetrol in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-11-2010, 11:19 AM
  4. Ally door inserts
    By RichardCranium in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-02-2009, 11:19 AM
  5. Question Steering Wheel Inserts...Any Good??
    By 11Riviera in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-08-2008, 01:06 PM
