Thread: Air Con Recharge - DIY?
Results 1 to 8 of 8
  1. Air Con Recharge - DIY?
    Apr 2013
    Shenfield, UK
    A/C on our 2 year old Q7 (less than 20k miles) isn't working too well. Personally I don't think it should need re gassing so soon, it could be a fault (we had something similar on our A4 a while back) or it could just need re-gassing.
    Anyone regassed their Q7 themselves? My RS4 also needs doing, so was thinking of buying a kit and doing it myself to both rather than lay £60 a car at kwik fit!
  2. Re: Air Con Recharge - DIY?
    New Forest
    80 Post(s)
    Similar with mine. just on 2-years old and nowhere near as cold as it should be.
    Sent from my STV100-4 using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  3. Re: Air Con Recharge - DIY?
    Apr 2013
    Shenfield, UK
    At least its not just ours, ours is almost 2 years to the day. Just got the reminder to do the road tax!
    Going to run a vcds scan when I get home, see if there are any fault codes.
  4. Re: Air Con Recharge - DIY?
    Mar 2018
    GB
    19 Post(s)
    Aircon needs a specific amount of refrigerant and oil, these happy clappy top up merchants have no real idea, download into a vacuum and correct measurement is the only way. Too much is as bad as too little.
    If he covers your area John @ www.airconditiongforcars.co.uk, is a top lad even gives advice for free on common faults, but a decent specialist is better than a kwikfit cowboy.
    Sent from my SM-G900F using Tapatalk
  5. Re: Air Con Recharge - DIY?
    New Forest
    80 Post(s)
    Quote Originally Posted by bill.wj.wilson View Post
    Car Air Conditioning and Demisting, Diagnosis Repairs Recharging in Kent UK, Mobile Service, Pocahontas In Ebbsfleet
  6. Re: Air Con Recharge - DIY?
    Apr 2016
    Stansted
    169 Post(s)
    Quote Originally Posted by elrao View Post
    I had mine done when it went in for the 2 year service a couple of weeks ago. I didn’t think there was an issue but since I’ve got it back it does seem like it can blow colder. Could be imagining it though!
    Former Q7 owner
  7. Re: Air Con Recharge - DIY?
    Feb 2004
    Yorkshire
    49 Post(s)
    I think the recommended interval is two years.. I have just had both my cars done and it does make a big difference...
    People seem to think that gas should not escape, but over time it does and it can lose quite a bit through seals... plus how do you know a new car has the full amount in...
    I would advice against refilling yourself you can overfill which will cause more problems, and expensive... Plus a proper service will also add oil to lubricate the system.. For what it cost get it done professionally...
    In fact you now need to be certified to service AC system, so technically you could be breaking the law.. https://www.gov.uk/guidance/qualific...ntaining-f-gas
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  8. Re: Air Con Recharge - DIY?
    130 Post(s)
    1972 Post(s)
    Technically speaking regassing an AC system without qualification and licensing is illegal with some quite punitive punishments involved.
  1. Please Help VW Golf GT TDI PD 150 - 2003 Aircon recharge.
    By yydelilah in forum Golf MK4 - 1999 - 2004
    Last Post: 14-06-2011, 07:27 PM
  2. Air con recharge failed
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-03-2011, 09:50 PM
  3. Question Air Can recharge service
    By djmx5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2010, 12:00 PM
  4. bora1.9tdi(115) Aircon recharge????
    By Nato558 in forum Bora - 1998 - 2005
    Last Post: 22-07-2008, 01:02 PM
  5. Where is Aircon Recharge Point on Passat TDI 2003?
    By shairaz1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-06-2007, 10:43 AM
