Thread: Neutral position sensor
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Neutral position sensor
    Nov 2013
    Stoke on Trent
    Hi folks, has anyone got any pics of where the neutral position sensor is located ? My car is a 2012 tdi golf estate CAYC. The stop start function has never worked since taking ownership last April. My VCDS shows the following:
    Vcds error code:
    10444 - Neutral Gear Sensor
    P15A1 00 (109) -Implausible Signal.
  2. Re: Neutral position sensor
    131 Post(s)
    1973 Post(s)
    It is on the gearbox itself buried down the front.
  3. Re: Neutral position sensor
    Nov 2013
    Stoke on Trent
    Cheers Crasher, i was hoping you would add your wealth of knowledge to this one. How would i access it ? From the top or bottom, and what bits would i need to remove to gain access to it. Thanks again.
  4. Re: Neutral position sensor
    131 Post(s)
    1973 Post(s)
    Private message me your reg number and I will have a look.
  5. Re: Neutral position sensor
    Nov 2013
    Stoke on Trent
    Pm sent mate
  6. Re: Neutral position sensor
    131 Post(s)
    1973 Post(s)
    Hmmmm, some odd and conflicting information, I will try and have a deeper look at work but I am only managing half days at the moment.
  7. Re: Neutral position sensor
    Nov 2013
    Stoke on Trent
    Cheers Crasher
  8. Re: Neutral position sensor
    Nov 2013
    Stoke on Trent
    Hi Crasher, did you get a chance to look any further into this ?
    Simon
  9. Re: Neutral position sensor
    131 Post(s)
    1973 Post(s)
    No I forgot, prod me tomorrow.
  10. Re: Neutral position sensor
    Nov 2013
    Stoke on Trent
  1. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  2. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  3. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
  4. maf sensor position??? Help
    By chrissgoduk1985 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-04-2008, 11:03 PM
  5. Cam Position Sensor
    By zenmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2007, 10:57 AM
