Thread: Passat Oxford 18 inch Wheels paint Code
Results 1 to 10 of 19
  1. Passat Oxford 18 inch Wheels paint Code
    May 2018
    HOUGHTON LE SPRING
    I have a 2016 Passat 2.0 GT in Reflex Silver. It has 18 inch Oxford Anthracite alloy wheels, factory fitted as far as I know, but I can not find out the paint code for them. I need to touch up some areas on them. VW themselves do not know what the colour is. Can anyone help?
    Thanks.
  2. Re: Passat Oxford 18 inch Wheels paint Code
    May 2012
    Everywhere
    308 Post(s)
    Usually found on ETKA .
  3. Re: Passat Oxford 18 inch Wheels paint Code
    46 Post(s)
    GT usually comes with Dartford, are you sure it isn't these?
    If you PM me your VIN or reg I can check which ones are fitted exactly to your vehicle.
  4. Re: Passat Oxford 18 inch Wheels paint Code
    May 2018
    HOUGHTON LE SPRING
    Thanks. EKTA site has others but not Oxford.
  5. Re: Passat Oxford 18 inch Wheels paint Code
    May 2018
    HOUGHTON LE SPRING
    Hi there, they are definitely Oxford Anthracite, exactly the same as in VW brochure. EKTA website do not mention them. VIN is, WVWZZZ3CZHE038289
    Thanks.
  6. Re: Passat Oxford 18 inch Wheels paint Code
    46 Post(s)
    Dartford is listed for that VIN
  7. Re: Passat Oxford 18 inch Wheels paint Code
    May 2018
    HOUGHTON LE SPRING
    The previous owner must have asked for Oxford wheels on it then. I don't know why EKTA site does not show them if they can be fitted from new, or at least the VW brochure says you can have them on the GT model. Thanks for your input on this. Much appreciated.
  8. Re: Passat Oxford 18 inch Wheels paint Code
    Nov 2017
    Cambridgeshire
    10 Post(s)
    Quote Originally Posted by Chris View Post
    Those wheels are Oxford Anthracite - there is no reference to a Dartford wheel in the VW brochure for any model (SE Business has London which is at least geographically close!)
    2015 Passat B8 2.0TDi 150 GT Estate in Deep Black
    2005 A2 1.4TDi 75 SE in Silver
  9. Re: Passat Oxford 18 inch Wheels paint Code
    May 2018
    HOUGHTON LE SPRING
  10. Re: Passat Oxford 18 inch Wheels paint Code
    46 Post(s)
    Quote Originally Posted by tez150 View Post
    Thats 110% Dartford, identical to what came on mine.
  1. New Passat B8 - 19 inch wheels
    By jameswrush in forum Passat - B8 Forum - 2015 -
    Last Post: 18-02-2018, 05:03 PM
  2. Paint code(s) or paint for 20" Rotor wheels
    By john2107 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-03-2014, 10:49 AM
  3. Can I change 18 inch wheels for 17 inch wheels?
    By dln6376 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-03-2014, 09:49 AM
  4. Passat paint code
    By donniep in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-02-2012, 03:14 PM
  5. Question Monte Carlo wheels paint code 17' (5 Spoke)
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-09-2011, 10:00 PM
