Thread: Golf Mkv Exhaust Pressure Sensor G450
  1. Golf Mkv Exhaust Pressure Sensor G450
    Sep 2017
    Plymouth UK
    Hi All,
    Hoping someone can advise...
    I came back from a shot journey (100 mile round trip) last night and the Engine Management Light came on when I stopped for fuel and restarted, when I got home I connected VCDS which revealed the faults listed below, I cleared these faults and the following day took it for a 70 mph drive in 4th for a while, hoping to initiate a regenerate of the DPF should it need it, I did about 30 miles in total (about 10 in 4th) and went for a walk, when I returned an hour or so later and started the car the Engine Management Light came on, going by the VCDS log below I'm hoping all I have to do is replace the "Exhaust Pressure Sensor" (EPS), what do you think? could it be that the other faults are being caused by the EPS malfunction?
    Also, If I do replace the EPS, does anyone know how to set it up in VCDS?
    Thanks in anticipation
    001137 - Exhaust Pressure Sensor 1 (G450)
    P0471 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 42
    Reset counter: 40
    Mileage: 125312 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:27:21
    Freeze Frame:
    RPM: 800 /min
    Torque: 40.0 Nm
    Speed: 0.0 km/h
    Pressure: 0.0 mbar
    Text: 112 C
    Text: 21 mbar
    Temperature: 15.0°C
    009299 - Diesel Particle Filter; Differential Pressure Sensor
    P2453 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 42
    Reset counter: 40
    Mileage: 125312 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:27:21
    001139 - Exhaust Pressure Sensor 1 (G450)
    P0473 - 006 - Signal too High - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 25
    Reset counter: 40
    Mileage: 125188 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:19:06
    Freeze Frame:
    RPM: 2112 /min
    Torque: 200.0 Nm
    Speed: 0.0 km/h
    Voltage: 12.32 V
    Mileage: 250 km
    Text: 132 C
    Pressure: 1001.1 mbar
  2. Re: Golf Mkv Exhaust Pressure Sensor G450
    Jan 2006
    Sounds like you need a new sensor on the DPF.
  3. Re: Golf Mkv Exhaust Pressure Sensor G450
    129 Post(s)
    1972 Post(s)
    VCDS has the login codes and details in pop up boxes when you go into adaptations and login.
  1. Question Fitting A New G450 Sensor (Exhaust Pressure Sensor)
    By VAG in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-05-2018, 02:16 PM
  2. Exhaust pressure sensor G450 parts shortage
    By Richs3 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-11-2013, 12:10 PM
  3. Exhaust gas pressure sensor
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-01-2012, 10:37 AM
  4. Exhaust pressure sensor
    By DMitch16 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2012, 10:30 PM
  5. G450 exhaust pressure sensor
    By autobrake3 in forum Golf MK6 - 2009 - 2013
    Last Post: 26-09-2011, 09:28 PM
