Thread: Stop Start not working
Results 1 to 10 of 16
  1. Stop Start not working
    Jan 2010
    Yate UK
    17 Post(s)
    My Stop Start has't done it's thing for over a week now. I've done plenty of long journeys so not a DPF regen issue (that seems to disable it for a while) and nice and warm weather so temperature not a factor.
    Same in all Drive Select modes so I don't think that's a factor.
    It shows the A with a circle on the DIS with a line through it when I am stopped and in neutral, like it would do if too cold to operate.
    Any ideas? Service due in a few weeks so I can get them to look at it then, but curious as to what it could be.
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
  2. Re: Stop Start not working
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    If your cabin temp is not near what you have it set at then it wont activate start stop. If not that then it may be worth getting the car scanned for any error codes.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  3. Re: Stop Start not working
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    low battery voltage?
  4. Re: Stop Start not working
    May 2018
    GB, Shoreham By Sea
    I have noticed a little trick that works. Disable the stop start with the button while the engine is running, switch the engine off then on and then go for a quick drive
    Sent from my Pixel 2 XL using Tapatalk
  5. Re: Stop Start not working
    Jan 2010
    Yate UK
    17 Post(s)
    Quote Originally Posted by dojadaff View Post
    That worked! Thanks - for some reason it came back on the journey after the one I was expecting but all good now.
    C6 2.0 TDI LE
    A4 2.0 TDI SE
  6. Re: Stop Start not working
    Tripletrouble Guest
    I'd quire happily have my stop-start permanently disabled.
  7. Re: Stop Start not working
    Jan 2010
    Yate UK
    17 Post(s)
    Found the problem! One of the kids had turned the air con in the back to 16 degrees and it was blowing so hard it was keeping the engine running to compensate. I only realised when I heard the fan.
    0 2 0
  8. Re: Stop Start not working
    Nov 2016
    Preston
    9 Post(s)
    kids eh? little monkeys
    Awaiting A6 Avant Quattro SE Executive 3.0 TDI 218ps.
    Metallic Diamond beige, adaptive air suspension, Bose surround sound, LED matrix headlights, parking pack, technology pack, ambient lighting, heated folding mirrors, comfort seats, privacy glass and finally a swivelling ball!
  9. Re: Stop Start not working
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by nevbadger99 View Post
    Use the sync button. Overrides the back.
    My little monkey does it all the time.
    Other option is use the mmi and change the back air con controls.
  10. Re: Stop Start not working
    Jan 2010
    Yate UK
    17 Post(s)
    Quote Originally Posted by A6S View Post
    I had no idea that button existed, thank you! I'm sure on my C6 you pushed in the rotary temperature control and that did a one off sync. I guess now I have the 4 zone system it us different.
  1. Replies: 1
    Last Post: 16-03-2020, 10:14 PM
  2. Start/stop feature not working?
    By nilli in forum Q7 - 4M Forum - 2016 -
    Last Post: 10-11-2018, 10:30 PM
  3. Replies: 0
    Last Post: 25-06-2014, 01:27 PM
  4. Please Help Automatic Start\Stop not working
    By Splatman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-10-2012, 07:27 PM
  5. Stop/Start not working?
    By breedop in forum Bluemotion
    Last Post: 10-06-2010, 08:55 PM
