Thread: Just bad luck or stupid, p068A
  1. Just bad luck or stupid, p068A
    Hi to All,
    been a will since visiting the Forum.
    long story short, 2011 golf gti mk6 70K, idle surging problems then engine warning light, suspect air leak. Changed the PCV, ran the car for a few minutes, all good, decided to have lunch and return and cancel the warning codes. Feeling quite happy at this point.
    BUT
    Returned to car, turned ignition on, tried to cancel fault code ( this seemed different to other occasions when cancelling fault codes, unless I made a mistake, code would not cancel).
    Tried to start car but indicator dash lights just repeatedly flashed with the classic latching unlatching relay sound, very weak almost nil crank.
    Ran another code and p068A was added to previous codes( previous codes related to air leak ).
    Charged battery (just in case ) have good head lights and blinkers, no indication of low battery ( to me ).
    Locked the car up over night, thinking time. Opened the driver door today to a chirping sound.
    My gut indicates just bad luck something failed ( remember the car did start and run prior to lunch ) or most likely I have triggered something when trying to disable the fault code.
    Any help resolving this would be most welcomed. The engine compartment fuses visually appear o/k, from memory there are two relays. I can pull these and do an external check if this is accessible but unsure if the relay will work properly when reinstalled ( may not receiving power ). Just about out of my depth now.
    Best wishes
    John
  2. Re: Just bad luck or stupid, p068A
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    VAG Error Code: 001674/4629
    EOBD II Error Code: P068A
    Fault Location:
    Engine Control Module (ECM) Power Relay Load
    Circuit - De-Energized Performance too Early/Opens too Early
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Fuse(s).
    Ignition Switch faulty.
    Wiring and/or Connector(s) from/to Power Supply Relay (J271/J317) faulty.
    Possible Solutions:
    Check/Replace Fuse(s).
    Check Wiring and/or Connector(s) from/to Power Supply Relay (J271/J317).
    Check/Replace Power Supply Relay (J271/J317).
    Note: A weak Battery may set this fault code. Insure the Battery voltage is at least 11.5v.
    As taken from my new EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Just bad luck or stupid, p068A
    130 Post(s)
    1972 Post(s)
    Sounds like a dead cell in the battery, it happens......
  4. Re: Just bad luck or stupid, p068A
    To Crasher,
    Amen brother
    to Keithuk,
    Many thanks for the reply.
    The RossTech VD.. is a magnificent tool, just be wary of the interpretation. I did find all your information but fell foul of the layman' rule, attend to the obvious first.
    It indicated that the battery had to hold a good charge so in anticipation I did charge the battery ( all night). All looked good the next morning but I thought that some more knowledgeable Forum member would request a full fault code print out. More fault codes were presented, still with the latching and unlatching relay sound. More thinking time and after looking at the fault printouts I noticed low battery readings of 8 to 10 volts. This surely can not be as I had the battery on charge all night.
    New battery, no faults All is good.
    I know batteries die very quickly, but to change the PCV, start the engine, go inside for lunch ( 1/2 hour ) then find a dead battery.
    The battery Tech suggested a cell had collapsed in the battery.
    I will try and repost the whole story in the appropriate section, it just save some poor soul further heart burn.
    Regards
    John
  5. Re: Just bad luck or stupid, p068A
    130 Post(s)
    1972 Post(s)
    I get weird **** all the time, I have stopped asking why.... The other week we had an A3 with a faulty instrument panel. My ODIS system was down so I booked it in with a friend. The next morning I jumped in to go and do the job and the ABS light was on. My friend did not have time to investigate so I did it with VCDS when I got back. The ABS pump had lost its coding but I had a code read from when it came in so I copied and pasted the coding across and it refused. I got a specialist ECU chap out and he spent 3 hours battling it. A friend of his at Audi in Germany told him to enter a certain incorrect code which it accepted and then he changed it to the right code, which it accepted..... bloody computers in cars!
  6. Re: Just bad luck or stupid, p068A
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Progress !!!
  1. bad luck followed by good luck on rear door lock
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-03-2015, 04:06 PM
  2. No luck
    By Matt482 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-06-2012, 12:48 PM
  3. good luck followed by bad luck
    By aaudi4 in forum Chat - Adult Banter
    Last Post: 25-04-2011, 09:29 PM
  4. Please Help Headlight harness plug...stupid is as stupid does, but...
    By ozwoldA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2011, 11:17 AM
  5. not much luck
    By new to vw in forum Audi A4 - Archive Topics
    Last Post: 31-03-2007, 01:19 AM
