Thread: asb engine g28 sensor?
  1. asb engine g28 sensor?
    Jul 2008
    Lisburn
    16 Post(s)
    Car is stuck at the local shop. A scan threw up p0321 - engine speed sensor g28. I am going to have to change it in the car park but struggling to find any info on how to its not in elsa... found a dodgy you tube says it's above the left hand drive shaft. Does any one know? Odds are it will be raining as Well when i get the part....
    Stewart.
  2. Re: asb engine g28 sensor?
    Jul 2008
    Lisburn
    16 Post(s)
    Replac3d it no diffetence. I did fit it without spacer, don't notes good day. But sorted that and no diffetence. Any thing else you'd can think of
    Thanks..
  3. Re: asb engine g28 sensor?
    Jul 2013
    76 Post(s)
    Have you confirmed that the wiring to the sensor is good?
    If the new sensor is not duff then does the flywheel teeth look ok.
    If you can get a camera on a stick into the sensor hole and turn the engine by hand.
    http://forums.quattroworld.com/s4s6/msgs/281029.phtml
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: asb engine g28 sensor?
    Jul 2008
    Lisburn
    16 Post(s)
    Thanks for the reply been trawling the web and found out if the rev counter works the sensor is good and that p0321 sensor out of range is a FFS or no sugar Sherlock moment for obd2. Basicly means your engines not started mate.... other posts have pointed towards fuel issues and to be fair in hindsight it does come across as that. The fuel gauge has been messing about for a while, out of habit i reset trip and keep an eye on fuel consumption and possible issues so i know it's got fuel but on the same hand possible wiring issues in the tank...... fingers crossed
  5. Re: asb engine g28 sensor?
    Jul 2008
    Lisburn
    16 Post(s)
    I have started another thread but thought I should close this one out. 3 wired sensor uses power so confirmed the outer wires had 5v present. Current theory is the timing has jumped a tooth....
  6. Re: asb engine g28 sensor?
    Jul 2008
    Lisburn
    16 Post(s)
    thought i would close this out -
    the 5V was a white lie i measured 2.5 but as the battery was dead i assumed that it was ok at 5.
    on the strength of 2.5V and a weak signal the ECU went back to bosch to be refurbished, turns out 2.5 is expected at the crank sensor.
    the actual fault was damage to the sensor ring due to something coming off the clutch.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. Cmp sensor engine speed sensor fault
    By rswa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2022, 10:44 PM
  2. Replies: 0
    Last Post: 27-11-2013, 09:36 PM
  3. Question Bora - Engine judder when driving - MAF sensor, temp. sensor or ABS fault??
    By Christo3000 in forum Bora - 1998 - 2005
    Last Post: 20-06-2011, 05:29 PM
  4. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  5. Engine speed sensor - crankshaft sensor
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-05-2011, 09:56 AM
