Thread: Dodgy fuel gauge Fault code 00771, unable to remove locking ring on pump
  1. Dodgy fuel gauge Fault code 00771, unable to remove locking ring on pump
    Oct 2016
    NE Scotland
    Hi people.
    I'm having issues with my fuel gauge on my A6 C6 2.7tdi Quattro going to zero now and then and fuel showing 0 miles when plenty left in the tank. Plugged in my diagnostic and get the fault code 00771.IMG_3668.jpg
    Any ideas, i was thinking a dodgy fuel sensor but thought id take the pump out to have a look but wow i cant shift the white locking ring, been at it with a hammer and screwdriver but refuses to move unless im missing something. Here is a pic of the pump in situ.
    Any help greatly appreciated. Was going to get a sensor from ebay but have read about broken wires etc but cant get the bloody thing off!!!
  2. Re: Dodgy fuel gauge Fault code 00771, unable to remove locking ring on pump
    H,
    I had this it was the connection in the fuel tank between the two sender units, I disconnected it and cleaned.
    Too remove the outer ring you need to tap alternative sides as per the photo, gently or you will break it. Make sure you’ve got as little fuel as possible in the tank.
    I made a mark on the sender, outer ring and the paint work as a reference.
    When refitting push the sender into position and tighten up by hand the outer ring then again tap alternate sides till tight.
    This is where the marks you made earlier will help.
  3. Re: Dodgy fuel gauge Fault code 00771, unable to remove locking ring on pump
    Oct 2016
    NE Scotland
    Thanks ever so much for your reply, What did you use to clean the connections may i ask, I've ordered up a tool to get the locking ring off so hopefully have it in a few days. I was wondering if it may be the connection on the top as pictured as I've took it off and gave it a blow and a clean etc and the gauge works again for a few days then mucks up again but working at the moment.
    Whats the best method for cleaning them?
    cheers
  4. Re: Dodgy fuel gauge Fault code 00771, unable to remove locking ring on pump
    No worries, I cleaned the connector with some brake cleaner on a rag. Even now I can get a random day when it stops working then it’s fine again for 6 months even though I’ve not touched it.
  1. Dodgy Fuel Gauge
    By Timpey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2014, 07:51 PM
  2. How to recalinrate steering wheel slip ring. fault code 01826
    By Adman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-10-2012, 07:51 PM
  3. Fuel pump issue now Fuel Gauge shows wrong amount
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2012, 05:53 PM
  4. faulty fuel gauge or fuel pump
    By martyn brooks in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-01-2011, 10:03 PM
  5. Question How to Remove A3 Central Locking Pump
    By Jimmyboo in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-02-2010, 01:44 AM
