Thread: golf bonnet closing problem
  1. golf bonnet closing problem
    hi there, i have an 04 mk 5 golf tdi
    i opened my bonnet to check the oil today and now it won't close. the catch comes in but it doesn't go all the way down. now the handle to open the bonnet doesn't feel 'right' when i pul it. any advice?
    thanks
  2. Re: golf bonnet closing problem
    Coventry
    possibly lacking lubrication.
    If access is still possible, i suggest an application ov wd40 to the cable and or grease or copper grease to the catch mechanism.
    Incase the bonnet has become missaligned, before you force anything, check the gaps are equal between the bonnet and bothe wings.
    to check the catch, simulate the bonnet catch by using a screwdriver to operate the closing mechanism.
    I hope this helps.
    Ben
    EDIT - and welcome to the forum.
  3. Re: golf bonnet closing problem
    thanks! the wd40 worked like a charm!
    thanks a lot
    paul
  4. Re: golf bonnet closing problem
    Dec 2007
    www.uk-mobilestore.co.uk
    I have a same problem now, i got a vw golf mk5 the bonnet wont shut tried wd40 still wont shut
    can some1 give me advice
  5. Re: golf bonnet closing problem
    129 Post(s)
    1972 Post(s)
    This is getting common; the Octavia 2 suffers from this as well. The bonnet safety catch sizes up and won't allow the bonnet to latch. How long before an owner gets a windscreen full of bonnet?
  6. Re: golf bonnet closing problem
    BuyanythingbutaVW Guest
    The bonnet catch of my 55 plate Golf was changed about 6 months ago as after I opened the bonnet I couldn't get it to close. The RAC came out and took a section of the front grille apart and gained access to the bonnet catch. The RAC man and myself where amazed at how corroded the whole catch lock was. It was packed with loads of grease by the RAC and it eventaully closed again.
    RAC told me to get it changed when the car next went to VW and it was changed about three months ago under warranty. If your car is still under warranty then it should be changed for free.
    Yet again another piece of amazing build quality.
  7. Re: golf bonnet closing problem
    129 Post(s)
    1972 Post(s)
    VAG are close to not being able to afford to build cars in Europe due to labour costs so something has to give and that is parts quality. Even then, the Golf 5 is a seriously over complicated car to build, it take twice as long to build as an Astra or Focus-someone really screwed up!
  1. Bonnet catch
    By bograt in forum Audi A4 - Archive Topics
    Last Post: 14-08-2007, 02:13 PM
  2. Closing the bonnet on Mk IV GT TDI
    By steveh in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-02-2007, 11:07 AM
  3. Hatch closing
    By Mav2006 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-01-2007, 08:21 PM
  4. Bonnet Pull
    By Phil155 in forum Passat - Archive Topics
    Last Post: 02-01-2007, 06:49 PM
  5. W Reg Passat - Bonnet Release (at front of bonnet)
    By AndyD in forum Passat - Archive Topics
    Last Post: 01-01-2007, 06:09 PM
