Thread: Air quality sensor/automatic re-circulation
Results 1 to 10 of 11
  1. Air quality sensor/automatic re-circulation
    Jan 2018
    Hey guys. First post
    My manual says the car is fitted with Air Quality sensor (I guess it comes as standard with all A/C units?).
    It is supposed to shut off outside air if the air quality sensor detects any harmful gases coming from the outside traffic. It doesn't seem to work on my car though - I can still smell the outside air coming into the car if tailing behind a bus or something. Also the recirculation button never lights up, unless I press it intentionally.
    How does this work in your cars? Does the recirculation button light up on its own from time to time (when the air quality control kicks in)? Do you notice any smells from outside?
    My car is a 2015 Highline, "Automatic air recirculation" is switched on from the A/C menu. I am driving with A/C on "auto".
  2. Re: Air quality sensor/automatic re-circulation
    Jan 2018
    So nobody can confirm how this works on their B8? What I'd like to know before going to the service is:
    - does your your Recirculation button light up on its own from time to time (when the air quality function kicks in)?
    - do you smell exhaust gases from other cars from time to time?
  3. Re: Air quality sensor/automatic re-circulation
    Jan 2018
    Sussex
    55 Post(s)
    Its not that suffisticated more of a marketing trick.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
    1 1 0
  4. Re: Air quality sensor/automatic re-circulation
    Apr 2007
    Lancashire
    The recirculation function is manual but I think it closes when you put the transmission in reverse so as to prevent exhaust fumes being sucked into the car.
    It certainly doesn't self-close when you're behind a smokey diesel and I've never heard of that function on a VAG car. I wish it existed because I often close mine.
  5. Re: Air quality sensor/automatic re-circulation
    Jan 2018
    Quote Originally Posted by BenR View Post
    It certainly does Or it should...It's in my manual. Also on my car menu. Also on my dealer's website as a feature.
  6. Re: Air quality sensor/automatic re-circulation
    Jan 2021
    Bedzin, Poland
    Quote Originally Posted by lyubohar View Post
    This air quality sensor for sure is working, but I completely don't know what kind of fumes it detects. I know it "works" because if it is unplugged, there is an error on the dashboard.
    I live in very polluted area and I would like to have it working, but unfortunately it has never triggered air-recirculation. On the other hand, the humidity sensor opens the recirculator.
    So we know it is able to steer it. Maybe some more sensitive sensor is needed here? I don't know also why the people don't complain about it too much. And VW doesn't care about those few which they have received.
    My model is Passat MY2020, R-Line edition.
  7. Re: Air quality sensor/automatic re-circulation
    Jan 2018
    Quote Originally Posted by twinsen View Post
    You mean your recirculation is triggered without you doing anything and the little lamp on the button lights on its own?
  8. Re: Air quality sensor/automatic re-circulation
    Jan 2021
    Bedzin, Poland
    No no - engaging the closed circulation can be done only manually - the air quality sensor does not work at all (despite it has coding for maximum sensitivity). But if you unplug it's cable - there is an error on the dashboard, that the sensor has failed.
    That means, it DOES something, but most probably it does not react to the contaminated air, like in very polluted areas (with high concentration of PM10&PM2.5), and it also does not react to the exhaust gases from od diesel cars in front of you.
    BUT, the humidity sensor inside the car is able to OPEN the circulation to prevent windows from fogging. Definitely someone would investigate it why it is happening that it can open, but cannot close for good reason (fumes).
  9. Re: Air quality sensor/automatic re-circulation
    Jan 2018
    I know the reason - safety. You get your windows all misty and you crash.
    Anyway - my original question was could the Recirculation be activated by the car itself or mine is just broken. It seems it can't. As for the air filter - I think it does react to old cars in front of you, although a bit late - after you have already smelled the exhaust gas. At least this is my feeling from using the car for 4 years.
  10. Re: Air quality sensor/automatic re-circulation
    Mar 2013
    Brightlingsea
    8 Post(s)
    [Deleted]
    Last edited by MikeBz; 03-02-2021 at 10:58 AM. Reason: No obvious way to delete accidental post.
  1. Solved Rain sensor - Automatic wipers
    By nicktooley in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-10-2014, 03:23 PM
  2. Faulty automatic light sensor?
    By andyjgw in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-07-2014, 12:56 PM
  3. 01592 - Air Quality Sensor (G238)
    By gdallas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-06-2013, 08:27 AM
  4. SE B7 vs SE B8 for ride quality and cabin quality.
    By Pbro in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-08-2012, 08:32 AM
  5. MK5 Automatic Headlight sensor
    By russ21 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-11-2009, 02:38 PM
