Thread: vcds security code for A6 4F
Results 1 to 8 of 8
  1. vcds security code for A6 4F
    Sep 2017
    Paris (france)
    Hello everyone
    several weeks that I am looking for how to do a regeneration FAP for my Audi A6 4F 190ch (CANA). (security menu "11")
    all the codes tried on vcds do not work.
    example: for the menu (11) security code, 27971 refused, (accepted for "16" but refused for "11")
    security code for (11) , all refused ... 10016 ... 27971..10019..21295..30605 ..
    any help is welcome,
    thanks in advance
    edit : solved (EDC17)
    A6 2.7
  2. Re: vcds security code for A6 4F
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by Paris View Post
    Hello everyone several weeks that I am looking for how to do a regeneration FAP for my Audi A6 4F 190ch (CANA). (security menu "11") all the codes tried on vcds do not work. example: for the menu (11) security code, 27971 refused, (accepted for "16" but refused for "11") security code for (11) , all refused ... 10016 ... 27971..10019..21295..30605 .. any help is welcome, thanks in advance
    Have a look on Ross tech site, or if you have a genuine lead from them just email and they help you with the prob !!!
  3. Re: vcds security code for A6 4F
    Sep 2017
    Paris (france)
    thanks, but I had looked, he explains a manipulation that does not work on my A6 4F
    A6 2.7
  4. Re: vcds security code for A6 4F
    Nov 2017
    Scotland
    25 Post(s)
    you say you had done a full scan ?? you may already have the login-work shop code from the scan--if you saved it that is if not just scan again -since it will not be changed, as it did not acept the code you were tring to imput !!!===just a thought !! Have you tried coding instead of log in--ie-then you get long coding helper, log in may not be required !!!
  5. Re: vcds security code for A6 4F
    Sep 2017
    Paris (france)
    Quote Originally Posted by Vagnuts View Post
    Sorry I did not understand. (French)
    I summarize in image my problem, it can help,
    what I want is to force a regeneration of the fap, that is to say that ...
    DPF Regeneration Audi Q5 2.0 125kw - YouTube
    the code 27971 is well accepted (16) for my A6 4F (CAN)
    then on the video, the transition to the basic seting screen gives the possibility to make
    a regeneration on the video.
    me in basic seting i do not have that, look what i have ...
    so, I thought that by going through the II coding (11) I could force a regeneration of the fap.
    but no code II is accepted in this menu.
    I also tried that, but the code 10016 is not accepted in conding II (11)
    http://vagdata.de/4f-a6/dpf-zwangsre...v6-4f/?lang=de
    A6 2.7
  6. Re: vcds security code for A6 4F
    Nov 2017
    Scotland
    25 Post(s)
    Have you tried-- This one since,- other ones did not work "this should" !!!
    ((((((("""""Regeneration while Driving
    Prerequisites (General):
    • Ignition ON
    • Engine ON (Idle)
    • Coolant Temperature above 70 °C (see MVB 002.4)
    • Particle Filter Load below Specification (see MVB 108.2/3, VCDS should give the specified values)
      • If the Particle Filter Load is above Specification the Particle Filter needs to be replaced since the car may burn down when regenerating.
      • If the Particle Filter Load value in MVB 108 is blank, use alternate group 241.2/3 instead.
    • Power Consumers ON (Light, Seat Heating, Front/Rear Window Heater, Climate Control)
    • Engine Hood Closed
    Conditions (Driving Cycle):
    • Vehicle Speed above 60 km/h (40 MPH)
    • Engine Speed between 2000-2500 RPM (4th or 5th Gear, Automatic Transmission in Tiptronic)
    • Duration approx. 10-15 Minutes
    • Exhaust Gas Temperature before Turbo Charger above 170 °C (MVB 099.2)
    • Exhaust Gas Temperature before Diesel Particle Filter above 150 °C (MVB 099.3)
    • Exhaust Gas Temperature after Diesel Particle Filter above 150 °C (MVB 099.4)
    Drive the car based on the above Conditions until the Particle Filter Load is as low as possible (close to 0 %). In case the Regeneration fails there can either be problems with the Driving Cycle Conditions or with the Engine Hardware.
    [Select]
    [01 - Engine]
    [Security Access - 16]
    • Enter the Code shown by VCDS next to Adaptation Enabling (e.g. Regeneration while Driving)
    [Do It!]
    [Adaptation - 10]
    • Select Channel for Regeneration while Driving
    [Read]
    • Enter/Save 1 as new Value.
    [Save]
    [Done, Go Back]
    [Meas. Blocks - 08]
    Select Blocks 099 and 108 at once.
    [Go!]
    MVB 099.2: Exhaust Gas Temperature before Turbo Charger
    MVB 099.3: Exhaust Gas Temperature before Particle Filter
    MVB 099.4: Exhaust Gas Temperature after Particle Filter
    MVB 108.2 or 241.2: Particle Filter Soot Mass (calculated)
    MVB 108.3 or 241.3: Particle Filter Soot Mass (measured)
    Now Start the Driving Cycle and keep watching the Measuring Blocks (2nd Person required).
    [Done, Go Back]
    [Close Controller, Go Back - 06]""" )))))))
    2.7l/3.0l V6 CR-TDI (CAN)
    See Engine specific page.
    1.6l/2.0l R4 & 3.0l V6 CR-TDI (UDS)
    For engine controllers that use the UDS protocol (as shown on the top left corner of the Open Controller screen), ""Security Access is not typically needed when Service regeneration of particle filter while standing is supported"".
    • Ignition ON
    • Engine ON (Idle)
    • Fuel Tank at least 1/4 full
    • Transmission in Neutral/Park
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    • Use the pulldown menu and select Service regeneration of particle filter
    [Go!]
    [Show Measuring Data]
    • It would be useful to select items such as "Particle filter, soot mass calculated", "Particle filter, soot mass measured", and "Particle filter, time since last regeneration" to observe and verify the progress of the regeneration.
    • Due to the way UDS works, there may be differences in the locations and specific description for the values so you may need to search for the values you need.
    • Follow the Instructions on the Screen. These may include pressing and/or holding the brake, clutch, or accelerator.
    [Done, Go Back]
    From this page---http://wiki.ross-tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration --depending on what engine you have ??
  7. Re: vcds security code for A6 4F
    Nov 2017
    Scotland
    25 Post(s)
  8. Re: vcds security code for A6 4F
    Sep 2017
    Paris (france)
    sorry, I was sick, it's better now.
    let's go back to the problem:
    [01 - Engine] then [Basic Settings - 04] , I have no DPF menu
    motor runs and hot,
    what you tell me I did, without any result.
    I repeat myself, but I have the impression that the codes giving access to the cleaning of the DPF,
    are in the code "11" but no code is accepted at this place.
    for access "16" code 27971 accepted, but after, no access !
    look.
    in "adaptation" the same, nothing! ...
    in no menu, I do not find DPF.
    ( because ... no code "11" ? )
    edit : solved ! (cana EDC17)
    A6 2.7
  1. Please Help raidio security code?
    By rya4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2014, 01:31 PM
  2. VCDS Security Access Code - Audi A1?
    By releaseyourself in forum VCDS - General Questions
    Last Post: 04-06-2011, 03:07 PM
  3. Do i need a security code for VAG COM?
    By kevshek in forum VCDS - General Questions
    Last Post: 14-05-2011, 08:50 PM
  4. Please Help Security code for key
    By Decoy in forum Ibiza - Cordoba
    Last Post: 06-10-2009, 02:00 PM
  5. concert security code
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2008, 11:18 PM
