Thread: Rear parking sensors working intermittently?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Rear parking sensors working intermittently?
    Aug 2010
    St. Austell, Cornwall
    When going into reverse, I get the normal long beep to indicate reverse has been selected. Then sometimes I get the reversing beeps going crazy, sometimes they are fine for a few seconds, then go mental, sometimes they work perfectly fine.
    However, I'm panicking cos I keep thinking a child has run behind the car! So fixing it would be best.
    I've checked all the sensors, they are all clicking away happily. I've enabled the visual parking aid on the MMI screen but it looks like the sensors are playing up equally (I mean there isn't just one which is the culprit, it seems to be random).
    As this has happened after the car was left for a couple of months, I'm wondering if some moisture has got into the main sensor control unit? Anyone no where that might be? Maybe I could dry it out, WD40 it or something?
    No lights on the dashboard, just beeps like mad.
    Any help gratefully received!!
    Cheers, Ed.
    Audi A6 C6 2.0TDI MY2006 186,000miles.
  2. Re: Rear parking sensors working intermittently?
    Jul 2008
    Lisburn
    16 Post(s)
    mine did the same the click test lead me to believe it was a front center one. got myself an obd elevan and it is telling me it is rear center left. havent got it change yet, was going to swap the 2 center one to see if it is sensor or wiring
    having trouble with my clutch just now so it has fallen down the list ...
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Rear parking sensors working intermittently?
    Aug 2010
    But the click test leads me to believe that the sensors are ok, cos they are all clicking away. I need to find the main box, and try cleaning contacts or something.
  4. Re: Rear parking sensors working intermittently?
    Jul 2013
    76 Post(s)
    you ideally need a scan to tell which one or more is playing up.
    Whats happening is that the sensors are working just reading as if an object is close.
    Look at the sensors for a build up of crud ( or car wax) especially around the ring portion, also check that they flush with the bumper as if the have been pushed back due to cleaning this will cause the fault also.
    if you have access to VCDS then the measuring blocks for the sensors distance reading should be looked at to find the culprit/culprits.
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: Rear parking sensors working intermittently?
    Aug 2010
    Ok, I have a friend with VCDS so I'll get a log and see what it says. Cheers.
  6. Re: Rear parking sensors working intermittently?
    Jul 2013
    76 Post(s)
    The mesuring blocks will be better if no code is generated.
    You need to look at the parking distance readings, when they have no objects behind they read 255 you are looking for the ones with the smaller distance.
    Dan
  7. Re: Rear parking sensors working intermittently?
    Aug 2010
    Tried all solutions, but what worked in the end was removing fuses on the drivers side dashboard. Remove, clean fuse with sandpaper, spray electrical contact cleaner into fusebox, replace fuse. Repeat for all fuses.
    Took a while, but it’s been fine ever since. (Fingers crossed)
  8. Re: Rear parking sensors working intermittently?
    May 2007
    My parking sensors don't respond at all in A8 2008 facelift model The sensor button on the dash has no light either.
    Running the VCDS gives me the following readings
    Address 76: Park Assist Labels: 4E0-910-283.lbl
    Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
    Component: Parkhilfe 8-Kan H12 0040
    Revision: 00H12000 Serial number: 08740810504184
    Coding: 0221008
    Shop #: WSC 02313 785 00200
    VCID: 234FF155E2CED91
    3 Faults Found:
    01549 - Supply Voltage for Parking-Aid Sensor
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 183143 km
    Time Indication: 0
    Date: 2017.12.26
    Time: 17:46:34
    00576 - Terminal 15
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 183143 km
    Time Indication: 0
    Date: 2017.12.26
    Time: 17:46:34
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 183143 km
    Time Indication: 0
    Date: 2017.12.26
    Time: 17:46:34
    I would appreciate any help
    thanks in advance
  9. Re: Rear parking sensors working intermittently?
    Nov 2017
    England
    I’d be very interested in this as I’m having the same problem with the same fault codes as you drknmirza. I’m planning on opening the boot and trying to get to the ECU to see if I can figure out why but any tips would be helpful.
  10. Re: Rear parking sensors working intermittently?
    May 2007
    Quote Originally Posted by Hamta View Post
    I will try with checking the speaker first
    It’s behind the rear seat on the driver side.
  1. Rear parking sensors not working
    By monz87 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-06-2019, 01:24 PM
  2. Replies: 3
    Last Post: 26-05-2016, 10:40 AM
  3. CC Rear Parking sensors not working
    By wtd2008 in forum Chat - Anything with wheels
    Last Post: 19-02-2015, 02:27 PM
  4. Rear parking sensors have stopped working...
    By Saulmac in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-11-2011, 05:32 PM
  5. Parking sensors and rear view camera stopped working
    By Eddo1968 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-05-2010, 06:36 PM
