Thread: Fuel Temp Sensor
Results 1 to 10 of 20
  1. Fuel Temp Sensor
    Nov 2017
    Wiltshire
    Hi Guys
    (1.9TDI PD engine)
    Hopefully you can help!
    Recently had my check engine light come on with the code P0183 fuel temp sensor. I have changed the sensor and reset the light but the fault light comes back.
    Have now tested the old sensor with a multimeter and it appears to work with the resistance changing during a temperature input.
    Have checked other sensors on the engine with the ignition on,they are all getting a 5V supply.
    However my fuel temp sensor is only getting a 2.5V supply but it is showing a good earth. So the wires not broken.
    Any ideas on a next step. I'm stuck for ideas.
    Should it actually be a 5V supply?
    ECU fault?
    Is there two fuel temp sensors?
    Many thanks in advance!!
  2. Re: Fuel Temp Sensor
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by Bobs2293 View Post
    Hi Guys
    (1.9TDI PD engine)
    ECU fault?
    far as i know its just the one--did you clrear the fault, try ecu reset !!!
  3. Re: Fuel Temp Sensor
    Nov 2017
    Wiltshire
    I did via the code reader. It comes back every time
  4. Re: Fuel Temp Sensor
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by Vagnuts View Post
    silly question, but have you checked the fuse ???
  5. Re: Fuel Temp Sensor
    Nov 2017
    Wiltshire
    That specific sensor doesn't appear to have its own fuse. There is also a voltage there.
  6. Re: Fuel Temp Sensor
    Nov 2017
    Scotland
    25 Post(s)
    pos bad earth ?? I am just guessing at this point !!!
  7. Re: Fuel Temp Sensor
    Nov 2017
    Scotland
    25 Post(s)
    found this on Ross tech site---
    16567/P0183 - Fuel Temperature Sensor A (G81): Open or Short to Plus
  8. Re: Fuel Temp Sensor
    May 2007
    17 Post(s)
    I'm pretty sure the sensor should be supplied 5V from the ECU, like most other temperature sensors. The fact you have 2.5V at the sensor (measured against a known good ground) could mean either there is a high resistance between the sensor and the ECU, or the wire is shorted to ground. Reading the temperature on the scan tool (sensor connected) will tell you which it is.
    Assuming it's a common NTC sensor, a short to ground will cause the measured value to be higher than the true temperature. A high resistance in the wire will cause the measured value to be lower than true.
  9. Re: Fuel Temp Sensor
    Jul 2007
    glasgow
    35 Post(s)
    swap over the fuel sensor with the coolant temp sensor, should be the same sensor I think
    new sensors can be just as faulty, is it OEM from VW ?
  10. Re: Fuel Temp Sensor
    Nov 2017
    Scotland
    25 Post(s)
    in the fuel filter there is a temp control valve,if its caput, it might be letting cold fuel through all the time causing the prob-ie -it usually recirculates until fuel up to temp, then opens and starts to return to the tank-via the cooler under the drivers seat(under the car.haha) so as not to create to much condensation in the tank !!--its a long shot, but worth a looksee---No ????
  1. Fuel temp sensor
    By nigeld56 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2015, 10:27 PM
  2. Fuel temp. sensor A
    By ajmartins in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-04-2014, 09:11 PM
  3. Fuel temp sensor
    By PETER G in forum VCDS - Help Requests
    Last Post: 30-03-2010, 08:09 PM
  4. Question Fuel temp sensor
    By Ant1977 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 19-01-2010, 06:53 PM
  5. fuel temp sensor?
    By kernowsailor in forum The Commercial Range
    Last Post: 05-01-2009, 09:59 PM
